Pyramid3D v8.3.0 XE Sense 3.0
Št. objave:#1  OdgovorNapisal/-a rawdealer » 14 nov 2011, 15:37
Slika Slika Slika Slika Slika Slika
Najboljši in najhitrejši Sense ROM za Sensation in Sensation XE z Sense 3.0 UI
Freshly rebuilt from Official 1.73.401.2 XE ROM - Android 2.3.4
-show-p1984 kernel v1.45-Test O/C @ 1914Mhz Max - OnDemand, SmartASSv2, Performance
-Tested to be most stable and smooth kernel out for 2.3.4
-Very minimal but nice & smooth graphic enhancements
-Daemon O/C system with Daemon Controller app
-Custom speed init.d scripts
-FULL Beats audio integration fully optimized sound
-RAM Management inti.d scripts
-5x5 App Drawer
-NoSense Script - NEW!! - Thanks Mike1986 for the base script
-Page by Page scrolling disabled in app drawer
-Resized stock Android fonts
-Zipaligned on every boot for speed
-Data download speed improvements
-Updated Andreno config for speed improvements
-Updated Media profiles for better media quality
-Optional Full Arabic support - Thanks to mike1986
-Optional WiFi Calling patch for T-Mobile customers - Thanks Dwsmith for maintaining them
-Sliding Keyboard effect
-Adfree base updated regularly
-All HTC's snooping disabled
-Screen shot function (POWER + HOME Keys) - Disabled by default
-MULTI LANGUAGE - Now Including Chinese
-WiFi Driver improvements & greater range
-Greatly improved battery life
-Fast as hell
-Extended quick settings
-MMS Hack for bigger files
-MMS Backup and restore function - Thanks Capychimp
-Enabled GPU UI Rendering for speed (Hardware Acceleration)
-Rooted and Superuser added
-Setup scripts on install for better performance - Thanks Virtuous Team
-OI File Manger Included
-Unsecured boot.img
-Lots of tweaks for speed and memory improvements
-Multilanguage (WWE)
-Fully Zipaligned
-Fully de-odexed
-init.d scripts (BusyBox run-parts) support
-EXT 4 VERSION
-Very Fast & Fluid!
-Sense 3.0 UI
Changelog:
Koda: Izberi vse
Pyramid3D v8.0.0
Fully rebuilt from RUU - See updated feature list
- This version WILL WIPE YOUR USER DATA, so backup.
Added Bricked 0.91 Kernel with GPU O/C to 320Mhz - Tested stable for 24 Hours including 3D Gaming
- Tested to be most stable and smooth kernel out for 2.3.4 So please dont ask my why I didnt use the latest version, Latest doesn't always = the best
- Over 48 Hours testing had NO FC and NO FREEZE (Since using v0.91 Bricked)
Set CPU Clock back to 1.45Ghz stock - Trust me faster is not needed but go for gold lol
Removed Divider lines from menus
Fixed "Rough looking" Rosie Dock
Removed dock from lock screen
Disabled page by page scrolling
Updated fonts to stock Android resized (No longer looks stretched)
4G icon will now show inplace of H and 3G
Replaced Astro File Manager with OI File Manager (Much cleaner to use)
Removed libhtc_Loggers.so
Updated Hosts file to latest
Updated Maps
Removed volume wake - Will add a patch to enable
Added custom speed init.d script - Thanks vladnosferatu (Works well ;))
Removed CRT (Faster without it but will again make a patch)
Improved battery life
Made Beats wallpaper as default
Added Australian English to default list
Added Chinese to default list
Added Superuser 3.0.3 - (3.0.5 Has issues, If you get FC after market automatically updates just un-install updates)
Pyramid3D v7.9.2
Kernel fix
Pyramid3D v7.9.1
Fixed RAM script (Should have heaps more free RAM)
Updated Gmail
Updated Titanium Backup
Updated Superuser and Binarys
Updated Adfree
Updated Maps
Updated Facebook
Updated Adobe Flash
Removed App Sharing
Fixed light lock ring when selecting an app
Added ZRAM script
Added Volume button wake - Thanks jjdoctor
Lots more free RAM and better stability
Pyramid3D v7.9.0
Updated to Bricked kernel v1.2
Kernel ChangeLog:
> deep sleep reboots fixed
> wakeup problems fixed
> heating problem fixed
> GPU & CPU limited while screen off (increases battery savings)
> increased responsiveness on 2.3.5 (2.3.4 should profit too)
> increased 2D performance
> increased GPU voltage @ 320Mhz. Should make a few more phones stable with the enthusiast version.
> intruducing a new power saving feature while phone is in 2D mode.
     -This will make the phone stay cold as a rock while browsing the web/being in menus, and save battery
> resolved a crossed memory allocation
> fixed 2 memleaks
> fixed USB OTG
> fixed a WLAN authentification bug
> fixed a BT connection issue with some Headsets
> added power management features specifically for 2.3.5's new settings
> modified kernel side lowmem values. (0,1,2,4,7,15 | 2048,3072,4096,6144,8192,12288)
     -You may want to check if you rom chef is overwriting those values with a script in /system/etc/init.d/
> removed kgsl early suspend, this is not needed anymore.
> introduced a bunch of new fixes+features from the new kernel source I am currently merging.
Update Fusion
Added Semi-Transparent Navbar
Added Dark unlock ring
WiFi Range improvments
Updated Thermal Configuration
Improved battery
Updated low memory script to match kernel values
Fixes random reboots for good!
TONES smoother AGAIN!
Pyramid3D v7.8.2 - Small Update
Disabled screen capture again
> If you want to use it, use an app from the market or go to build.prop and change screencapture from "false" to "true", I dont like broken stuff in my ROMs and ill fix it when i have the time ;)
Pyramid3D v7.8.1 - Small Update
Added sliding keyboard effect - Thanks Capychimp for the advice :D
Removed all HTC's snooping and logging
Pyramid3D v7.8.0 - FULL ROM
Updated to Bricked kernel v1.0
Kernel ChangeLog:
> Works with 2.3.5 (Sense 3.5 leak)
> KGSL Early Suspend drivers (saves battery & reduces heat)
> KGSL Turbo Mode
> KGSL: Turn the clocks on before the power.
> drivers: misc: pass miscdevice pointer via file private data (by Samu Onkalo )
> Fixed possible null pointer refference
> prepared for badass governor (he hasn't made it in this release :()
> Tweaked ondemand to reduce battery usage
> Tweaks for the new libs
Added Themed wallpapers back into "HTC Wallpapers"
Updated Maps to 5.10.1 With WW Navigation
Updated Superuser
Added screen shot function back due to requests
Changed a few libs
Updated build.prop
Revised init.d scripts
Much, much smoother ROM
Battery should be a little better
Pyramid3D v7.6.2 - Small Update (11mb)
Updated Facebook - Again
Updated Google+ - Again
Revised Adreno Configuration and updated
Revised build.prop and made lots of tweaks
Changed wifi scanning back to 75 fix wifi scanning errors in low wifi reception areas
Added some init.d scripts
> Permissions fix
> Speed tweaks
Nice little speed improvements
Kako instalirat ROM:
NE UPORABLJAJ ROM MANAGERJA!!!
Če prihajaš iz drugega ROM-a ali na novo inštaliraš ROM, moraš najprej v Recovery brisati nekaj stvari:
-wipe data/factory reset
-wipe cache partition
-advanced ----> wipe dalvik cache
šele nato install zip from sdcard in chose zip from sdcard ;)
poiščeš mapo na SD kartici v katero si dal zip ROM-a in ga inštaliraš.
Ko se je inštaliralo kar si želel greš nazaj in stisneš reboot system now
Še bolj pa priporočam Super Wipe skripto, ker pobriše res VSE tako kot je treba....DL link na dnu posta.
Če pa inštaliraš samo novo verzijo ROM-a narediš prej naslednje:
Če karkoli downloadaš in uporabljaš si vzemi sekundo časa in pritisni gumb hvala. Toliko, da vem, da ni moj trud zaman ;) HVALA
Pyramid3D_v8.3.0_XE.zip (FULL ROM)
Ta zip flashaj, da ti bo kazalo H, E in 3G ikono namesto ves cas 4G, ce te ta moti.
Izkljucitev konstantne 4G ikone
5x4 Rosie FULL 3D
Blue NEON XE v3 (Tema)
SUPER WIPE
--- This script will erase and format your data, system and cache partition ---
--- Your SD card will remain untouched FAT32 and it's recommended to leave it like that ---
Super Wipe čisto enostavno "instaliraš" v recovery kot vsak drugi zip file (install zip from SD---choose zip from SD), le da se ne instalira nič, ampak ti namesto ročnega brisanja podatkov skripta pobriše sama vse podatke. Zelo priporočljivo je uporabljat to namesto ročnega brisanja (wipe data/factory reset, cache in dalvik cache), ker ima CWM 5.0.2.0 en bug, ki ne pobriše čisto vsega in lahko včasih pride do napak v ROM-u. Ta skripta pa pobriše popolnoma vse.....SD kartica ostane nedotaknjena, brez panike :D
Ko zaženeš preko instalacije v recovery bo nekaj časa delalo (sproti piše kaj počne) in se bo recovery ponovno zagnal, potem pa lahko flashas nov rom oz. restore.
Bricked 0.91 Kernel WITH O/C GPU @ 320mhz
> Overclockne GPU na 320MHz kar doda k hitrosti in tekočem delovanju UI....lahko pa, da ne deluje na vseh telefonih zato flashaj nazaj spodnji kernel, če boš imel težave.....<
(meni se je pretirano grel in občasno imel čudne "izpade", zato sem flashal kernel iz spodnjega linka)
Bricked-v0.91-ondmnd-1536-192.show-p1984.zip
Priporočljiv Radio:
Radio_10.58.9035.00U_10.15.9035.02_2.img
PG58IMG kopiraj na SD kartico, zaženi telefon v bootloader in sledi navodilom na ekranu
rawdealer
Re: Sensation + XE: ✰ Pyramid3D v8.2.1 XE ✰
Št. objave:#2  OdgovorNapisal/-a Fody » 10 dec 2011, 01:08
Zajle sem lih malo gledo rome po XDA. Pa sem naleto na tega pa http://forum.xda-developers.com/showthr ... ?t=1280358 da jih najbol hvalijo kolker vidim. Kaj to si ga dal si gor za opis samo al si ga mel sanso tud kaj bol sprobat kak deluje pa to?
Fody
Prispevkov: 196
Pridružen: 18 mar 2011, 16:27
Naprava: HTC Sensation
Št. objave:#3  OdgovorNapisal/-a rawdealer » 10 dec 2011, 01:57
Pravkar imam tega gor in pravkar je 8.3.0 nalozen na server (poglej xda)
Ta sense rom je najboljsi in najhitrejsi od vseh, ter brez odvecne navlake ;)
Tistega pa ne bom jaz dajal gor, ker je poln kica :) lahko nardis temo, ce ti je ;)
Sent from my S-OFF'd ultra Sensational phone
rawdealer
Št. objave:#4  OdgovorNapisal/-a Fody » 10 dec 2011, 02:15
Aha. Ce ti reces da je vredo te ze more bit glede na to da si vlki nasptrotnik sense romov. Nah saj ce je poln kica pol brezveze temo delat pa zavajat folk tu. Bom jaz jutri tud tega sprobal ko pridem iz sluzbe.
Fody
Prispevkov: 196
Št. objave:#5  OdgovorNapisal/-a Mitjap » 10 dec 2011, 03:11
Tole je pa kot sense na steroidih, bo treba sprobat :)
Mitjap
Prispevkov: 37
Pridružen: 15 okt 2011, 00:27
Št. objave:#6  OdgovorNapisal/-a rawdealer » 10 dec 2011, 09:51
Ok....poln kica je malo huda beseda, ima pa precej nepotrebnih stvari :D
Ta rom imam gor, da ga sprobam in lahko povem kako deluje itd. Edino kar grem pri tem romu najprej naredit je brisanje z root explorerjem par app iz systema, ker so odvec ;)
-4ext updater, da se mi ne nalozi 4ext recovery....najdes ga v data/app
-oc deamon (nekak tak) mislim, da je tudi v data/app, ker uporabim setCPU in bi se tepla med sabo (lahko pa ga pustita, ampak potem brez nalaganja setcpu!)
-oi file manager, potem ko nalozim root explorer, ker dveh ne rabim, najdes ga v system/app
-polaris office, ker instaliram quick office pro......system/app
-maps in facebook.....system/app ker so stare verzije vkljucene in nalozim zadnje verzije.
Uporabljam tisti kernel, ki nafrizira gpu na 320MHz in dela res lepo, je pa res, da je pravi mali pozeruh baterije, ampak ok, saj obstajajo polnilci :D
rawdealer
Re: Sensation + XE: ✰ Pyramid3D v8.3.0 XE ✰
Št. objave:#7  OdgovorNapisal/-a Fody » 11 dec 2011, 00:23
A onega bricked a ne?
Kak poziralec baterije je to? Ne zdrzi niti 16ur zmerne uporabe al zdrzi?
Fody
Prispevkov: 196
Št. objave:#8  OdgovorNapisal/-a Fody » 11 dec 2011, 18:27
Btw kak je z kamero kaj na tem romu? Kaj slabsa od stock roma al ista?
Fody
Prispevkov: 196
Št. objave:#9  OdgovorNapisal/-a rawdealer » 11 dec 2011, 18:36
Malenkost izboljsana. Imas Sensation? Probaj....
rawdealer
Št. objave:#10  OdgovorNapisal/-a Fody » 11 dec 2011, 19:06
Zajle sem ga lih s off pa CWM dal gor. Rootam se ga pa dam gor ta ROM :)
Fody
Prispevkov: 196
Št. objave:#11  OdgovorNapisal/-a Fody » 11 dec 2011, 19:12
Se pravi ko menjavas rome pa to je najbols vedno uporabit kr tisto scripto pa nic noter posebaj hodit brisat kot na Desiru?
Pa zaj ko grem iz stock roma jo tudi mores uporabit a ne? :)
Fody
Prispevkov: 196
Št. objave:#12  OdgovorNapisal/-a rawdealer » 11 dec 2011, 19:34
Tako je :))))
Lahko pa si tudi menjas splash, v htc forumu najdes temo.....res lepo pase na Sensation ;)
rawdealer
Št. objave:#13  OdgovorNapisal/-a Fody » 11 dec 2011, 20:33
Aha. Edino nekaj me muci. Ce grem z root explorerjem v System/app pa poiscem polaris office pa tapnem gor mi napise samo instal al pa view al pa cancel in kot vidim je to tudi samo .apk..Toraj ce dam delete bo mi samo .apk odstranlo ne pa polaris office a ne?
Pa se to...Flickr pa Stocks tud lahk dol vrzem ker mi gre preprosto na zivce da vidim to gor.
Fody
Prispevkov: 196
Št. objave:#14  OdgovorNapisal/-a rawdealer » 11 dec 2011, 20:42
Ce das DOLG STISK na app, ki si jo izbral imas opcijo delete.....odinstalira aplikacijo, Polar Office je aplikacija, zdaj nisem preprican, ce sem te razumel ali pa ti nisi ;D probaj in poglej ;) se prej pa moras oznacit mount R/W
rawdealer
Št. objave:#15  OdgovorNapisal/-a Fody » 11 dec 2011, 22:34
Aha sem mislo ko je blo na koncu .apk da je to samo tista instalacija in ne program sam..
Kaj stocks pa flickr lahk tud zbrisem tu ven al bo kaki problemi?
Flash sem pa tud porihto brez blema :) super program tisto
Fody
Prispevkov: 196
Št. objave:#16  OdgovorNapisal/-a rawdealer » 11 dec 2011, 23:45
Aplikacija alias program v starem windows pogovornem zargonu :) fody.apk je aplikacija ali pogosto uporabljeno tudi app (application) ;) apk je koncnica enako kot exe, pdf, doc, mp3, jpeg.....
rawdealer
Št. objave:#17  OdgovorNapisal/-a Fody » 12 dec 2011, 00:32
saj vem to :) Samo ce me razumes kaj hocem povedat je da sem mislo da je ta .apk tisti s katerim samo instaliras nekaj. in sem mislo da ce odstranim ta .apk bom samo odstrano .apk s keterim se ta app instalira in da ne bo odstranlo dejanskega instaliranega appa :P
Se vedno nisi povedo a lahko dam stocks pa flickr dol al pride lahk do kakih problemov na romu pol?
Fody
Prispevkov: 196
Št. objave:#18  OdgovorNapisal/-a KrLo » 12 dec 2011, 00:34
naredi backup , odstrani če se telefon čudno obnaša restoraj če pa ne pa si se rešo tvoje "nadloge" :D
Telefon: iPhone 7 Plus Black
Tablica: Asus Nexus 7 v2
Prispevkov: 28660
Prejete zahvale: 4802
Naprava: S7 Edge & Nexus 7 (2013) & LGGWR
Št. objave:#19  OdgovorNapisal/-a rawdealer » 12 dec 2011, 00:37
Kaj ti naj recem, nisem nikoli sensa uporabljal vec kot dve uri, lahko pa probas in vidis kako bo....naredi najprej backup potem pa brisi ven in ce ga bo kiksal se vrnes nazaj z restorom ali pa flashas rom preko, da se instalirajo vse system apps nazaj. Take stvari sem ponavadi jaz tako naredil brez drame ;D
Sem pa skoraj preprican, da nima kaj bit.
rawdealer
Re: Re: Sensation + XE: ✰ Pyramid3D v8.2.1 XE ✰
Št. objave:#20  OdgovorNapisal/-a rawdealer » 12 dec 2011, 00:42
Fody napisal/-a:Zajle sem lih malo gledo rome po XDA. Pa sem naleto na tega pa http://forum.xda-developers.com/showthr ... ?t=1280358 da jih najbol hvalijo kolker vidim. Kaj to si ga dal si gor za opis samo al si ga mel sanso tud kaj bol sprobat kak deluje pa to?
Takrat sem na hitro prebral in ga zamenjal za drugi rom....tudi ta rom je zelo dober ja, le da je Sense 3.5 in na osnovi zadnjega XE RUU-ja, ta pa 3.0 in na prejsnjem XE RUU-ju. Nekateri imajo raje Sense 3.5, drugi pac 3.0. Najmanj te pa stane probat in sam videt razlike med dolocenimi romi, to kar ti povedo drugi je vedno samo njihovo sukjektivno mnenje.... ;)
rawdealer
Št. objave:#21  OdgovorNapisal/-a Fody » 12 dec 2011, 00:47
Ja saj :)
Se mi je zdelo cudno da si ga tak skritiziro tede ja ker so ga kr fajn hvalili tam :) Se ta ga je hvalo od tega pyramid :)
Ja eni pravijo da 3.5 ni najbol kul trenutno. Najbol me muci da bi mel amaze camero ker mi zgleda sick vredo ono ko zajame 3 slike pa naredi vredo sliko ven. Sam jeba da mores met pa stock kernel :S
Fody
Prispevkov: 196
Št. objave:#22  OdgovorNapisal/-a Fody » 12 dec 2011, 01:07
To me se zanima.
http://forum.xda-developers.com/showthr ... ?t=1367021
Te lockringe lahko instaliras na ta ROM ce prav razumem a ne? Wipam cahce pa dalvik pa instal zip from SD card?
Ker neke sem bral v enih temah od deoxed pa no deoxed al kaj pa nimam pojma se atm kaj je tisto :P
Sam glede na to da pise da lahko das na sense 3.0 rome sklepam da tu gor lahko dam na ta rom kerkoli ring iz te teme ali se motim?
Hvala vnaprej :)
Fody
Prispevkov: 196
Št. objave:#23  OdgovorNapisal/-a rawdealer » 12 dec 2011, 09:35
Ja, piše da je za Sense 3.0 ROM-e in kako se instalira. :)
Deodexed % odexed ROM-i:
http://android.stackexchange.com/questi ... dexed-roms
http://forum.xda-developers.com/showpos ... ostcount=2
rawdealer
Št. objave:#24  OdgovorNapisal/-a Fody » 12 dec 2011, 11:34
Aha hvala ti
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
Fody
Prispevkov: 196
Št. objave:#25  OdgovorNapisal/-a Fody » 17 dec 2011, 15:20
Morem povedat da v 1 tednu uporabe mi je fon freezno 2x. Recimo gledo posnetek in dal back in freeze in edina resitev baterija ven in nazaj.
Tak da glede na to izkusnjo glih ne priporocam roma za vsakdanjo uporabo.
Fody
Prispevkov: 196
Vrni se na Zbirke ROM-ov
