Vivo X80 pro
34 prispevkov
• Stran 1 od 2 • 1, 2
Vivo X80 pro
Vidim, da je kar zanimanje za ta telefonček, potem si zasluži tudi svojo temo.
Nekaj osnovnih specifikacij predvsem za pro verzijo.
Tehnične podrobnosti:
Mere telefona: 164.6 x 75.3 x 9.1 mm
Teža: 215 g / 219 g
Telo: Glass front, glass back or ceramic back or eco leather back, aluminum frame
SIM: Dual SIM (Nano-SIM, dual stand-by)
IP68 dust/water resistant (up to 1.5m for 30 mins)
Zaslon: LTPO3 AMOLED, 1B colors, 120Hz, HDR10+, 1500 nits (peak)
Size: 6.78 inches, 111.4 cm2 (~89.9% screen-to-body ratio)
Resolution: 1440 x 3200 pixels, 20:9 ratio (~517 ppi density)
OS: Android 12, Funtouch 12 (Global), Origin OS Ocean (China)
Chipset: Qualcomm SM8450 Snapdragon 8 Gen 1 (4 nm)
MediaTek Dimensity 9000 (4 nm)
CPU: Octa-core (1x3.00 GHz Cortex-X2 & 3x2.40 GHz Cortex-A710 & 4x1.70 GHz Cortex-A510)
Octa-core (1x3.05 GHz Cortex-X2 & 3x2.85 GHz Cortex-A710 & 4x1.80 GHz Cortex-A510)
GPU: Adreno 730
Mali-G710 MC10
Spomin: Card slot: No
Internal: 256GB 8GB RAM, 256GB 12GB RAM, 512GB 12GB RAM
UFS 3.1
Zadnja kamera:
Quad 50 MP, f/1.6, (wide), 1/1.3", PDAF, Laser AF, OIS
8 MP, f/3.4, (periscope telephoto), 1/4.4", 1.0µm, PDAF, OIS, 5x optical zoom
12 MP, f/1.9, 50mm (telephoto), 1/2.93", 1.22µm, Dual Pixel PDAF, 2x optical zoom, gimbal OIS
48 MP, f/2.2, 114˚ (ultrawide), 1/2.0", AF
Features Zeiss optics, Zeiss T* lens coating, Pixel Shift, dual-LED dual-tone flash, HDR, panorama
Video: 8K, 4K@30/60fps, 1080p@30/60fps, gyro-EIS
Sprednja Selfi kamera:
Single 32 MP, f/2.5, 24mm (wide), 1/2.8", 0.8µm
Features HDR
Video: 4K@30fps, 1080p@30fps
Zvok: Loudspeaker: Yes, with stereo speakers
3.5mm jack: No
32-bit/192kHz audio
WLAN: Wi-Fi 802.11 a/b/g/n/ac/6, dual-band, Wi-Fi Direct, hotspot
Bluetooth: 5.2 (Snapdragon)/ 5.3 (Dimensity), A2DP, LE, aptX HD
GPS: Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO, QZSS, NavIC
NFC: Yes
Infrared port: Yes
Radio: No
USB: USB Type-C 3.1 (Global)/ 3.2 (China), USB On-The-Go
Baterija: Li-Po 4700 mAh, non-removable
Polnenje: Fast charging 80W, 100% in 38 min (advertised)
Fast wireless charging 50W, 100% in 50 min (advertised)
Reverse charging
Barve: Cosmic Black, Blue, Orange
https://www.gsmarena.com/vivo_x80_pro-1 ... 0%20%20%20
Teža: 215 g / 219 g
GPU: Adreno 730
Mali-G710 MC10
UFS 3.1
Zadnja kamera:
Features HDR
3.5mm jack: No
32-bit/192kHz audio
NFC: Yes
Infrared port: Yes
Radio: No
Reverse charging
Re: Vivo X80 pro
Še vedno gledam in gledam... Testi ki sem jih pregledal ima VIVO TOp kamero, sploh s LAICA softwareom - sploh v barvah.
Trenutno sem našel odlično ceno , ampak moraš imeti Avstrijski naslov.
https://www.dreiland.at/p/vivo-X80-Pro- ... ku=5661266
Ali kdo ima kakšen P.o. BOX v Avstriji, je kdo že kaj prakse imel , da imaš zakupljen predalček v Avstrijski pošti. (že dolgo razmišljam)
- Prispevkov: 3146
- Prejete zahvale: 302
Re: Vivo X80 pro
Mogoče nekaj vtisov iz moje strani po 10 dneh uporabe.
Torej, kupil sem ga po prednaročilu v BB na dan izida, to je v petek 15.7.
Prvi dan sem porabil, da sem nastavil telefon in aplikacije. Vedno, ko menjam aparat začnem setup iz nule, brez obnovitve podatkov/aplikacij. Porabim veliko časa, da vse nastavim, si pa zato prihranim morebitne glavobole kasneje..
Takoj naslednji dan smo šli na dopust za 7 dni na HR. Povprečni SOT, ki sem ga imel v tem tednu, je znašal nekje 5 ur s tem, da sem povprečno na dan naredil 20-30 slik in recimo 2 videa. Ostalo srfanje, Reddit, xda app, WA, VIber... S tem, da je bila temperatura okolice 32-35C, ekran skoraj vedno na max osvetlitvi (plaža), švoh wifi in 4G signal v kampu. Ekran na FHD/120Hz.
Trenutno doma pod klimo, SOT 5.5 ur in še vedno 40% baterije na razpolago.
Mogoče kratka primerjava z S22U:
- kamera: generalno, precej boljša na X80 pro, sploh v temnejših razmerah. S22U seveda zmaga v zoomu, vse ostalo pa ga po mojem Vivo šiša. Izjema oz tam tam sta po mojem s portrait (3x portrait od S22U vs. 2x portrait od X80). Ima pa kamera od X80 pro ogromno nastavitev in dejansko se še nisem utegnil poglobiti in testirati vse.
- baterija: izgleda, da bom prišel nekje na 9 ur SOT na domačem wifi. Za primerjavo, z S22U sem imel cca 7.5 ur v enakih pogojih. Nisem še imel možnosti testirati realne uporabe, se pravi mešano 4G zunaj/v službi ter wifi doma; tu sem imel z S22U povprečni SOT nekje 6,5 ur. Po mojem bo z Vivotom boljši.
Polnjenje je itak na Vivotu precej hitrejše.
- zvočniki: boljši/glasnejši na Vivotu
- ekran: S22U tu zmaga, predvsem ker je neverjetno svetel na direktnem soncu (dokler se ne začne pregrevati
) . Je pa tudi Vivotov ekran odličen in tudi adaptive brightness zelo lepo dela - primerljivo s Samsungom
FPS - enkraten, zelo hiter in zanesljiv. Tudi Samsungov je OK, ampak Vivo je v eni ligi višje.
- software: no, tu je prostora za izboljšave. OneUI je bolj spoliran in nudi več različnih možnosti. Funtouch je v primerjavi z OneUI bolj špartanski, ampak ima potencial. So pa kake nastavitve mogoče na nelogičnih mestih. Pa tudi npr. z nastavitvami baterije po posameznih aplikacijah, da pridejo obvestila za nekatere apps redno skozi, se je potrebno ukvarjati na 2 mestih v nastavitvah.
Toliko, da ne bom predolg. Če ima kdo kako vprašanje, z veseljem odgovorim.
- toby
- Prispevkov: 201
- Kraj: Koper
- Naprava: Vivo X80 Pro
Re: Vivo X80 pro
LPKA napisal/-a:Še vedno gledam in gledam... Testi ki sem jih pregledal ima VIVO TOp kamero, sploh s LAICA softwareom - sploh v barvah.
Tudi jaz sem našel to stran. Toda ne vem koliko je kaj zaupat tej-temu prodajalcu-spletni trgovini?
Ne vem, če nebi potem raje vzel v electronic4you, kjer je 100€ dražji - 1079€ Je pa le nekoliko bolj priznana trgovina?
Še vedno 120€ ceneje kot v BB kjer je sedaj 1200€
Je pa cenejši kot vivo X60 Pro.
Re: Vivo X80 pro
toby napisal/-a: Ostalo srfanje, Reddit, xda app, WA, VIber... švoh wifi in 4G signal v kampu...
No zelo me zanima, kako je z tem signalom, predvsem mobilnim signalom. Si oziroma imaš dobro povezavo v primerjavi, če si imel kakšen drug telefon zraven za primerjat, predvsem net, dobro lovi odpira določene spletne strani, predvsem na mestih kjer je malo slabši signal ali v kakšnih zaprtih prostorih?
Re: Vivo X80 pro
S signalom nisem opazil nobenih težav, ne z wifi kot tudi ne z mobilnim signalom. Vse dela hitro in bp.
Tukaj zraven sicer imam službeni S22, ki pa ima Telekomov SiM medtem, ko sem sam na A1 tako, da direktno ne morem primerjati. Sicer nimam najmočnejši signal doma, na Vivotu mi kaže -102 dBm medtem, ko je bil na S22U, če se prav spomnim, signal nekoliko slabši, nekje med -108 in -112 dBm.
Sem pa pognal Speedtest za wifi na X80 pro in na službenem S22:
Vivo 592 Mbps
S22 369 Mbps
Vivo 592 Mbps
S22 369 Mbps
- toby
- Prispevkov: 201
- Kraj: Koper
Re: Vivo X80 pro
Lahko prosim pogledaš ali ima možnost e-sim v nastavitvah
- Prispevkov: 3146
Re: Vivo X80 pro
Včeraj sem kupil X80 Pro in prvi vtisi so odlični. Performanse odlične, glede baterije pa teško kaj rečem zaenkrat. Kamera odlična sprobal par fotk in so odlične tudi v slabi svetlobi oziroma temi. Mislim pa,da je telefon vredn nakupa mogoče malce prevelika cena ampak ok.
blinkt - AncientDroid
- Prispevkov: 1619
- Prejete zahvale: 201
- Naprava: Huawei P30 Pro, Acer Iconia,S10+
Re: Vivo X80 pro
sva že dva z X80 pro na tem forumu torej
- toby
- Prispevkov: 201
- Kraj: Koper
Re: Vivo X80 pro
blinkt napisal/-a:Včeraj sem kupil X80 Pro in prvi vtisi so odlični. Performanse odlične, glede baterije pa teško kaj rečem zaenkrat. Kamera odlična sprobal par fotk in so odlične tudi v slabi svetlobi oziroma temi. Mislim pa,da je telefon vredn nakupa mogoče malce prevelika cena ampak ok.
Kje si ga kupil, za kolk denar?
Re: Vivo X80 pro
toby
Če ne bi imel vivota ali bi bil še vedno druga izbira S22 ali bi bilo kaj drugega?
Re: Vivo X80 pro
Mars
Še vedno S22U ali pa morda Oppo Find X5 pro, ki se ga trenutno da dobiti za cca 950 EUR (global version).
Oppo pa drugače tudi zato, ker sem imel Find X2 pro s katerim sem bil zelo zadovoljen in tudi ColorOS sploh ni slab skin oz. kvečjemu obratno (podoben OneUI po fukncionalnostih/opcijah, spomnim se zelo gladkega delovanja na X2 Pro ..)
Pri X5 Pro je zame edini večji minus telephoto kamera s samo 2x povečavo in brez OIS.
- toby
- Prispevkov: 201
- Kraj: Koper
- Prispevkov: 1619
Re: Vivo X80 pro
Trenutno je na nemškem Amazon znižan na dobrih 1100 €.
Pri nas v BigBang je 1200 €
- toby
- Prispevkov: 201
- Kraj: Koper
Re: Vivo X80 pro
Ne vem ali se samo meni zdi, ali pa res telefon zelo kuri baterijo. Čez noč od 23:00 do 5:00 v stanju mirovanja wifi in ostalo vse OFF.. porabil 3% baterije. Tudi med uporabi sicer ne čutim pregrevanja ali karkoli ampak se mi zdi, da vsake toliko časa procenti kar padajo. Uporabljam 60hz, Svetlost nekje 40%, Edino, kar je možno, da zato, ker je telefon še nov in se še ni prilagodil oziroma stabiliziral. Pomoje bo po parih polnjenjih tako kot mora bit.
Vseeno ma mogoče kdo kakšen nasvet kako izboljšat baterijo al pa mogoče kaj spremenit v nastavitvah itd...
Drugač telefon je dobesedno TOP
- Prispevkov: 1619
Re: Vivo X80 pro
3% ni nič. Še vedno lahko v ozadju "tečejo" kakšne aplikacije. Pa tudi signal vpliva.
Meni včasih tudi do 10%(ne vivo). Res mobilni, wifi, lokacija, sinh. na on. Čisto odvisno, od signala, pa dobiš kakšno sporočilo, mail, pa kakšne aplikacije tečejo v ozadju. Verjetno pa se bo baterija še malo stabilizirala po parih polnenjih ja.
Re: Vivo X80 pro
Ta poraba čez noč se mi zdi čisto normalna, tudi meni porabi cca 3% z wifi in mobilnimi podatki na OFF. Toliko mi je porabil tudi S22U, pa pred njim S21U...
Verjetno se bo baterija v nekaj dneh stabilizirala. Sam nisem nič omejeval porabe, kvečjemu obratno, nekaj aplikacij sem dal med izjeme glede omejevanja porabe.
- toby
- Prispevkov: 201
- Kraj: Koper
Re: Vivo X80 pro
a se zajebavaš, meni v vseh 30 telefonih ponoči nobeden ni preživel s manj kot 10%.. 3% so moje božanske želje (no mogoče p30 pro - ampak sem že malo pozabil na tega - še vedno zakon)
- Prispevkov: 3146
Re: Vivo X80 pro
Ja samo moraš upoštevat to, da ima vse izklopljeno. To je pa meni itak potem kr neki. Zakaj bi sploh imel pameten telefon, da bi vse izklapljal. Zato ga imam, da sem na tekočem kaj dogaja. Če že, da me ponoči ali takrat ko nočem, da me moti, izklopim zvonenje.
Nisem pa preverjal koliko mi pokuri baterija, se ne spolnim, razen v takih trenutkih. Pač dam polnit, glede na potrebe. Še to naj bi spremljal. Meni ponoči oziroma brez uporabe pokuri približno 1,5% na uro.
Re: Vivo X80 pro
A se že dajo kje naročat kakšni ovitki. Iščem ovitek knjigico ampak za X80 Pro ne najdem, da bi bilo pri nas kaj. Iščem pa tudi zaščitno steklo za display in za zadnji del za kamero.
- Prispevkov: 1619
Re: Vivo X80 pro
Pri nas boš težko kje dobil. Najboljša opcija je preko amazon de. Še posebej, če imaš koga ali kaj iz avstrije, pa da dobiš še brez poštnine
Re: Vivo X80 pro
Evo po enem tednu uporabe, baterije definitivno boljša kot v samem začetku. Fotografije itak odlične mogoče zoom ni najboljši kot pri drugih high end telefonih ampak ok. Malo se še moram navadit na vmesnik ampak zaenkrat sem namestil Microsoft Launcher, ki mi je nekak boljši od Nova launcherja čeprav imam tudi tega kupljenega. Mogoče me moti avtomatska raven svetlosti vsaj v mojem primeru, ni ravno natančna. Sama hitrost je izjemna tako pri igrah kot drugih aplikacijah, nameščanje le teh je zelo hitra. Kar se tiče pregrevanja sem včeraj imel nekoliko bolj vroč telefon, ko sem sprobal Real Racing 3 in igral nekje 30 minut, se je telefon precej segrel na zgornji strani. Ampak je temperatura hitro padla nazaj na normalo. Sicer osebno imam zdaj nastavljeno pametno prestavljanje osveževanja ter višjo resolucijo in vse igre nastavljene na naj višjo možno kvaliteto. Posnetki z kamero tudi top nisem še sprobal 8K ampak se mi zdi brezveze, ker itak nimam kje gledat 8K videov in nebom videl neke razlike.. Snemam predvsem 1080p 60fps..
Plusi
Baterija
Performanse
Kvaliteta
Polnilec itak 80w top zadeva polnjenja
Zaslon ter kvaliteta le tega
Minusi
Dizajna(malo me moti ta velik del okrog kamere)
Vmesnik bi lahko bil boljši
Mogoče pregrevanje ob uporabi nekaterih iger
Plusi
Baterija
Performanse
Kvaliteta
Minusi
- Prispevkov: 1619
34 prispevkov
