Huawei P40, PRO, PRO+
Št. objave:#1  OdgovorNapisal/-a Picaso » 27 mar 2020, 13:05
Huawei P40 5G
General
Model: P40 5G
Release date 26th March 2020
Dimensions: 148.90 x 71.06 x 8.50(mm)
Weight: 175g
Battery capacity: 3800(mAh)
Removable battery: No
Fast charging Proprietary
Wireless charging: No
Colours Black, Blush Gold, Deep Sea Blue, Ice White, Silver Frost
Display:
Screen size: 6.10 (inches)
Resolution 1080x2340 pixels
Aspect ratio 19.5:9
Hardware:
Processor 2.86GHz octa-core (2x2.86GHz + 2x2.36GHz + 4x1.95GHz)
Processor make HiSilicon Kirin 990 5G
RAM 8GB
Internal storage 128GB
Expandable storage Yes
Expandable storage type Nano Memory Card
Camera:
Rear camera 50-megapixel (f/1.9) + 16-megapixel (f/2.2) + 8-megapixel (f/2.4)
Rear autofocus Yes
Rear flash Yes
Front camera 32-megapixel (f/2.0) + Infrared-megapixel
Front autofocus No
Software:
Operating system Android 10
Skin EMUI 10.1
Connectivity:
Wi-Fi Yes
Wi-Fi standards supported 802.11 a/b/g/n/ac/Yes
GPS Yes
Bluetooth: v 5.10
NFC Yes
Infrared: No
USB Type-C: Yes
Headphones: Type-C
Number of SIMs 2
Sensors:
Face unlock Yes
Fingerprint sensor Yes
In-Display Fingerprint Sensor Yes
Compass/ Magnetometer Yes
Proximity sensor Yes
Accelerometer Yes
Ambient light sensor Yes
Gyroscope Yes
Huawei P40 Pro
Body: Glass front and back, aluminum frame; IP68-rated for dust and water resistance.
Display: Screen 6.58" quad-curved OLED, 1,200x2,640px resolution (440ppi); HDR10.
Chipset: Kirin 990 5G, octa-core processor (2xA76 @2.86GHz + 2xA76 @2.36GHz +4xA55 @1.95GHz), Mali-G76 MP16 GPU, dual-core NPU.
Memory: 8GB RAM, 256GB UFS3.0 storage (expandable via Nano Memory - hybrid slot).
OS/Software: Android 10, EMUI 10.1.
Rear camera: Primary: 50MP (RYYB filter), 1/1.28" sensor size, 23mm f/1.8 lens, OIS, PDAF; Telephoto: 8MP (RYYB filter) 1/4.0" with periscope 125mm f/3.4 OIS lens, 5x optical and 10x hybrid zoom, PDAF; Ultra wide angle: 40MP (RGGB filter), 1/1.54", 18mm, f/1.8, PDAF; ToF camera; 4K@60fps video capture, 720@7680fps slow-mo; Leica co-developed.
Front camera: 32MP, f/2.2, 26mm; ToF camera.
Battery: 4,200mAh; Super Charge 40W; 27W wireless charging; reverse wireless charging.
Security: Fingerprint reader (under display, optical), 3D face recognition.
Connectivity: 5G/4G/3G/GSM; Dual SIM, Wi-Fi 6+, Dual-band GPS, Bluetooth 5.1 + LE, NFC, USB Type-C.
Misc: IR blaster, acoustic display acts as earpiece, bottom-firing loudspeaker.
Huawei P40 Pro + (plus)
Launch
Status
Rumored (Not officially announced)
Network:
LTE, 5G
SIM
Dual SIM
Dimensions: 158 x 73.4 x 8.4 mm
Weight: 192g
Build
Front/back glass, aluminum frame
IP69 protection against water and dust
Display: OLED
Size
6.7-inch
Resolution
1440 x 3120 pixels, Quad HD+
Pixel Density
550 PPI
Hardware:
Chipset: HiSilicon Kirin 990 (7nm+ EUV)
CPU: Octa-core (2x2.86 GHz Cortex-A76 & 2x2.36 GHz Cortex-A76 & 4x1.95 GHz Cortex-A55)
GPU: Mali-G76 MP16
RAM: 12GB
Internal Storage: 512GB
Card Slot: Nano Memory, up to 256 GB (uses SIM 2 slot)
Sensors:
Fingerprint , ambient light, accelerometer, gyro, proximity, compass, barometer
FM Radio: Yes
Audio Features
32-bit/384kHz audio
Active noise cancellation with dedicated mic
Dolby Atmos sound
Software:
OS: Android 10
User Interface: EMIUI 10
Camera:
Primary: Penta 52MP, f/1.8 (wide) + 8MP, f/2.4 (telephoto) + 16MP, f/2.2 (ultra-wide) + 3D ToF VGA
Video Rec.
2160p@60fps, 1080p@120fps, 1080p@30fps (gyro-EIS), 720p@960fps super slo-mo
Features
Leica optics, dual-LED dual-tone flash, panorama, HDR
Secondary: 40 MP, f/2.0 (wide)
Connectivity:
Bluetooth: 5.0, A2DP, aptX HD, LE
Wi-fi: 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct
Wi-fi Hotspot
USB: v3.1, Type-C 1.0 reversible connector
GPS: Yes, with A-GPS, GLONASS, BDS
NFC
3.5mm Jack
Battery:
Li-Ion (Lithium Ion)
4500 mAh, 45W fast charging
Fast Charging
Wireless Charging
Placement: Non-removable
https://consumer.huawei.com/si/phones/p40/
https://consumer.huawei.com/si/phones/p40-pro/
https://consumer.huawei.com/en/phones/p ... lus/specs/
Prispevkov: 6560
Prejete zahvale: 834
Re: Huawei P40, PRO, PRO+
Št. objave:#2  OdgovorNapisal/-a motoristic » 27 mar 2020, 13:10
Ne dvomim, da odlicni telefoni a...zal zame osebno brez googlovih servisov neuporabni.
Ker je cas za upgrade... kdo ve a LG V60 sploh pride k nam?
Prispevkov: 587
Prejete zahvale: 44
Št. objave:#3  OdgovorNapisal/-a matej1990 » 27 mar 2020, 13:45
PUF! In Galaxy S20 Ultra naenkrat več nima tako zanimivih foto specifikacij.
Fino bi bilo imeti v prvem postu specifikacije za vsako P40 verzijo.
Ampak bog pomagaj, tale izrez na ekranu je res pravi fail. Da bi vsaj bil res čisto na robu ekrana, ne pa da zareže proti sredini.
Prispevkov: 313
Prejete zahvale: 48
Št. objave:#4  OdgovorNapisal/-a Borg » 27 mar 2020, 16:10
Vse lepo in prav. Sem bil že full zagret, da bo to moj naslednji fon. Toda ko sedaj vidim ta "notch" me je pa vse minilo.
Že na Samsungu S10+ ga nisem prenesel to je pa še 10x slabše.
Samo res, morajo pa z eno samo malenkostjo vse uničit. Še Samsung je pogruntal, da je to napaka in gre naprej in ga prestavi na sredino.
Ne ti butlni pa gredo nazaj. Ja kdo bo potem to kupoval za 1000-1300€ pa še brez Googla.
Pa Google me še ne moti to bi še preživel samo to... >:(
Borg
Prispevkov: 67
Pridružen: 07 okt 2014, 01:37
Št. objave:#5  OdgovorNapisal/-a de marco » 27 mar 2020, 19:22
Se strinjam kdo bo to sploh kupoval pomojem je tema brezveze odprta
Prispevkov: 2056
Prejete zahvale: 158
Št. objave:#6  OdgovorNapisal/-a Picaso » 28 mar 2020, 10:11
What's the difference?
Huawei P40 vs P40 Pro vs P40 Pro Plus:
-Performance:
All models: Kirin 990 processor, 8GB RAM
P40 Pro & Pro+: 4,200mAh battery
P40: 3,800mAh battery
P40 Pro+: 40W fast-charging (incl. 40W wireless)
P40 Pro: 40W fast-charging (incl. 27W wireless)
P40: 22.5W fast-charging (no wireless charging)
-Screen: Size & Resolution:
P40 Pro & Pro+: Edge-to-edge 'Overflow Display' with curved edges / P40: Flat display
P40 Pro & Pro+: 6.58-inch OLED, 2640 x 1200 resolution
P40: 6.1-inch OLED, 2340 x 1080 resolution
P40 Pro & Pro+: 90Hz / P40: 60Hz
-Cameras:
P40: Leica triple camera system
P40 Pro: Leica quad camera system
P40 Pro+: Leica penta camera system
Main camera:
All models: 50MP SuperSensing (RYYB) sensor, 1/1.28in size
f/1.9 aperture, optical stabilisation (OIS)
Focal length (approx): P40 at 27mm, Pro at 25mm, Pro+ at 24mm
Ultra-wide camera:
P40: 16MP, f/2.2, 17mm equiv.
P40 Pro & Pro+: 40MP cine lens, f/1.8, 18mm equiv.
Zoom lens #1:
P40 & Pro+: 3x optical (80mm equiv.), 8MP, f/2.4, OIS
P40 Pro: 5x optical (125mm equiv.) RYYB sensor, 12MP, f/3.4, OIS
Zoom lens #2:
P40 Pro+: 10x optical (240mm equiv.) periscope zoom, 8MP, f/4.4, OIS
P40 Pro & Pro+: Time-of-Flight (ToF) depth sensor
All models: Dual selfie camera, 32MP
-Design: Colours & Finishes:
P40 Pro & Pro+ only: Silver Frost, Blush Gold with matte-touch finish
P40 Pro+ only: Black ceramic, White ceramic
All models: Ice White, Black, DeepSea Blue
-Price, Release Date & Conclusion
P40: €799 / Release 7 April
P40 Pro: €999 / Release 7 April
P40 Pro+: €1399 / Release date TBC
Prispevkov: 6560
Št. objave:#7  OdgovorNapisal/-a LPKA » 30 mar 2020, 00:17
Borg napisal/-a:Vse lepo in prav. Sem bil že full zagret, da bo to moj naslednji fon. Toda ko sedaj vidim ta "notch" me je pa vse minilo.
totalno enako mnenje. Sem bil šokiran. Notch groza, prevelik -pretežak pa predrag.
čakam na ONEPLUS 8, ali pixel 4a
Prispevkov: 3026
Prejete zahvale: 278
Naprava: SGNOTE10/Fenix6Titanium
Št. objave:#8  OdgovorNapisal/-a Borg » 30 mar 2020, 09:38
Ja bomo videli kaj bo ONEPLUS dal letos ven. Edino tukaj še vidim upanje ::)
Sem bil že za sedemko zagret pa me je tudi potem minilo. :D
Borg
Prispevkov: 67
Št. objave:#9  OdgovorNapisal/-a Maxl » 30 mar 2020, 14:40
de marco napisal/-a:Se strinjam kdo bo to sploh kupoval pomojem je tema brezveze odprta
Zakaj tako misliš?
Pill hole je res velik, ampak ima vsaj funkcionalnosti kot so 3D odklepanje, 4K video s stabilizacijo, itd.
Sicer pa se da Google Services in ostale aplikacije brez težav naložiti...
Maxl
Prispevkov: 819
Pridružen: 23 jan 2011, 16:59
Prejete zahvale: 105
Naprava: Huawei P30 Pro 8+256
Št. objave:#10  OdgovorNapisal/-a matej1990 » 30 mar 2020, 15:19
Fora je, da brez G Services in ostalih G appov je to le še nišni mobitel. Bo precej razočaranih ljudi ob nakupu. Verjetno bo tudi precej debate v tej temi glede pomoči. :)
Prispevkov: 313
Prejete zahvale: 48
Št. objave:#11  OdgovorNapisal/-a de marco » 30 mar 2020, 16:09
+1
Poslano z mojega SM-F900F z uporabo Tapatalk
Prispevkov: 2056
Št. objave:#12  OdgovorNapisal/-a motoristic » 30 mar 2020, 22:15
To, da se dajo google services enostavno naloziti SPLOH ni RES!
Zaenkrat se na novo serijo P guglovih servisov ne da naloziti.
Pa tudi na mate 30 ne deluje vec...
Prispevkov: 587
Prejete zahvale: 44
Št. objave:#13  OdgovorNapisal/-a matej1990 » 09 apr 2020, 18:22
Življenje brez Googla: Sorry Huawei, the P40 Pro without Google apps is just too broken to live with
Ampak Huawei pa še kar dalje na polno rine s telefonom v EU. V SLO so bili precej agresivni z oglaševanjem. Nisem pričakoval takšnega pusha. Prednaročila normalno na Mimovrste, Big Bang,...
Komotar (ok je ambasador znamke) je na veliko zagovarjal mobitel (+Mate Xs) in da brez Google appov ni problema.
"kako bo s prenosom aplikacij, če ne bo več na voljo Googlov Playstore." Brez skrbi, za vse je, oziroma bo poskrbljeno.
vse bo delalo tip top. Samo način namestitve bo drugačen.
Ni edini, tukaj je še Dinotti, ki je naredil YT review in enako rekel, da appi niso problem, ker se vse prenese. :D
Tudi pri A1 OcenjevA1nica so povedali, da to ni nič drastičnega. Da če ni appa, se lahko spletne verzije koristijo ali pa če se znajdeš, najdeš appe na spletu. ::)
Huawei jim polaga besede v usta. Ampak ej, marketing in influencerji delajo čudeže dan danes.
Tole jih zna drago stati, če bodo zvesti uporabniki razočarani, ker nimajo ponujenih alternativnih appov. Po moje bi morali še počakati s prodajo v EU, dokler ne najdejo dostojnih alternativ. Ker tole s Phone Clone appom je prava žalost.
Prispevkov: 313
Prejete zahvale: 48
Št. objave:#14  OdgovorNapisal/-a de marco » 09 apr 2020, 18:25
Ja so kar agresivni :)
Prispevkov: 2056
Št. objave:#15  OdgovorNapisal/-a nikonja » 09 apr 2020, 19:10
Po meni to zna bit kar veliki minus za večino posebej ker cenovno aparat ni tolk ugoden. Za enak dnar dobiš S20 in na njem vse dela brez zaj. z play storom.
Zaenkrat svet brez Googla ali Appla je žal kar zaj..
Sent from my SM-G973F using Tapatalk
nikonja
Prispevkov: 197
Pridružen: 09 sep 2011, 23:54
Naprava: Samsung Galaxy S4
Št. objave:#16  OdgovorNapisal/-a markic22 » 09 apr 2020, 22:09
Pa tukaj je se veliko vec v ozadju... Brez google play service bo delalo cedalje manj aplikacij, ki niso direktno povezane z googlovim storitvam (na prvi pogled). Cedalje vec aplikacij uporablja Firebase kot nadomestilo za streznik/bazo in tega nimas brez google play service. Tudi notificationi znajo bit vprasljivi...
Sent from my SM-G985F using Tapatalk
markic22
Prispevkov: 1958
Pridružen: 26 maj 2011, 10:42
Kraj: Ljubljana/Novo mesto
Prejete zahvale: 426
Št. objave:#17  OdgovorNapisal/-a motoristic » 09 apr 2020, 23:23
Pa ne delajo spletne (appi) banke..
Zal brez googla to ni poslovni telefon. Hudica niti za 11 letnega mulca ne (sploh ne za tak denar).
Jaz sem do zadnjega upal, da bodo resili spor in sem zelel probati huaweija (ker je glih cas za menjavo)..
Prispevkov: 587
Prejete zahvale: 44
Št. objave:#18  OdgovorNapisal/-a DownTaker » 10 apr 2020, 11:35
Če prav razumem potem podpirate gradnjo monopola Googlu?
Ni vse črno in belo. Jaz sem zato da je konkurenca.
Huawei se je odločil za svojo strategijo in vizijo. Konec koncev imajo pod sabo veliki Kitajski in azijski trg. Kakorkoli se obrne, propadli ne bodo. Kar se pa tiče razvoja in tehnologij, pa so Kitajci vsaj konkurenca Applu in Googlu.
Zato pa se je Trump (najbrž s kolegi iz ZDA) ustrašil konkurenta, ki je močno ogrozil njihovo "jabko" in tudi Googla.
Vsak naj uporablja kar mu ustreza. Ampak nikoli pa ne zagovarjajte monopola, ker potem se lahko zgodi da bodo trpele določene vrednote.
DownTaker
Prispevkov: 115
Pridružen: 27 sep 2012, 19:00
Naprava: Huawei Mate 20 Pro, Samsung Galaxy S6
Št. objave:#19  OdgovorNapisal/-a markic22 » 10 apr 2020, 12:41
Ne vem kje si videl, da kdo podpira ban? Ali pa monopol?
Bolj kot ne je tukaj govora o zavajanju in potencialnem razocaranjem koncnih potrosnikov huawei naprav, ki se ne zavedajo posledic uporabe Android sistema brez google play services. Sam sem osebno kar nekaj osebam moral razlagati kaj to pomeni.
Lahko pa konstruktivno poves kako bo lahko nekdo te pomanjkljivosti nadomestil (to kar smo zgoraj omenjali)?
markic22
Prispevkov: 1958
Št. objave:#20  OdgovorNapisal/-a matej1990 » 10 apr 2020, 15:10
DownTaker napisal/-a:Če prav razumem potem podpirate gradnjo monopola Googlu?
lol, glede podpiranja gradnje monopola. Huawei bi v trenutku "stekel nazaj" h Googlu, če bi to bilo možno, ti pa sedaj zagovarjaš Huawei kot da so se svojevoljno ločili od Googla zaradi njihovega monopolnega položaja. :D
Huawei se ni odločil za svojo strategijo in vizijo. V njo je bil prisiljen zaradi USA bana.
Huawei ni konkurenca Googlu, so še vedno partnerji. In še precej časa bo tako.
Prispevkov: 313
Prejete zahvale: 48
Št. objave:#21  OdgovorNapisal/-a de marco » 10 apr 2020, 17:05
So blackberry in microsoft (tudi nokia) probali konkurirat pa ni šlo tko, da nima nobeden šans brez googla.
Prispevkov: 2056
Št. objave:#22  OdgovorNapisal/-a Mtd » 10 apr 2020, 18:12
+1. Tudi Apple bi imel ne malo problemov, če bi z Appstore-a zginili vsi Google appi.
S tem, ko so na voljo, je Apple obdržal kar nekaj strank, pa oni recimo celo imajo alternativo.. :)
Prispevkov: 2244
Prejete zahvale: 497
Št. objave:#23  OdgovorNapisal/-a DownTaker » 10 apr 2020, 21:44
Ja in kaj drugega ste zdaj povedali kot to kar Google hoče slišat od vsakega, ki drži v roki telefon :D
Vse je v navadah in temu, kako smo fleksibilni.
Saj jaz tudi uporabljam podobno kot večina. Ampak, če kdaj česa ne bo več, bom pač iskal alternative. Življenje bo teklo dalje...
DownTaker
Prispevkov: 115
Št. objave:#24  OdgovorNapisal/-a Mtd » 10 apr 2020, 21:56
Ma, ni problem v Google aplikacijah, koliko je recimo za primer @gmail.com mail, ki ga ima na pamet rečeno, prek 300 ljudi, s katerimi sem/še vedno poslujem.. če ni iPhone oz, če ni Android z google framework-om, ne deluje, ga ne moreš dodat. Zato recimo je s tega razloga že problem met telefon, ki tega ne podpira..
Itak, da bomo vsi našči alternative, če bomo primorani. ;) Tudi zdaj jih moramo, ko smo še vedno doma.. :D
Se pa vsekakor strinjam, da je konkurenca vedno dobra ter dobrodošla, v končni fazi pridobi največ uporabnik.
Prispevkov: 2244
Št. objave:#25  OdgovorNapisal/-a Nekdo11 » 10 apr 2020, 23:01
Sam sem pred 10 leti kupil samsung wave z bada OS. telefon je bil boljsi harswersko kot tedanji galaxy S1 (kovinsko ohisje, fotoaoarat z bliskavico...) in seveda občutno nižjo ceno, ker sem verjel, da bo samsung pa ja zalaufal svoj sistem. No, resnica je bila, da si je hitro premislil in v bado vlagal prakticno nic, ponudba aplikacij porazna dokler po nekje 3. letih niso dokončno ugasnili sistema. Lansirati jim je uspelo lih 1 malo večjo posodobitev, potem so probali s tizenom, ki je tudi fail, vsaj kar se telefonov tiče. Ampak huawei pa se res trudi. Opažam, da prihajajo na huawei app tudi ze velike firme (snapchat naprimer), tako da v njih pa dejansko verjamem, da jim bo uspelo, ker imajo popolnoma drugačen pristop. So tudi bolj odvisni kot je bil samsung od svojega, saj je v 99,9% podpiral android, lastnega sistema pa praktično nič.
Nekdo11
Prispevkov: 305
Pridružen: 22 sep 2012, 18:34
Naprava: Galaxy S2,Htc One M8,Galaxy S7, P30 Pro
