SmartQ TEN3 (DualCore OMAP4430 / GPU: SGX540)
Št. objave:#1  OdgovorNapisal/-a Tomson » 22 feb 2012, 17:44
Da se ne smeti po drugih temah odpiram tole za TEn3 tablet, ki počasi prihaja na tržišče. Nekaj stvari je že znanih, nekaj je še neznanka, predlagam da se tukaj objavijo sproti znane zadeve ...
Gre za priznano podjetje z elektroniko na Kitajskem, ki ima od vseh manj poznanih imen (Onda/Cube/Icoo/Uppo/Window) daleč največji renome, znani so po kvalitetnih izdelkih in rednih updejtih.
DELNO POTRJENE SPECIFIKACIJE:
* 9.7 Inch 1024 X 768 IPS Display
* Dual Core TI OMAP4430 1.0GHz / GPU: SGX540
* 10 points Capacitive Touch Screen
* 8GB Flash Memory (supports SDHC 32GB cards)
* 1Gb DDRII Ram
* 2Mp Front camera
* USB 2 ports
* Wifi 802.11 b/g/n
* External 3G
* 7500mah Battery
* Android 4.0 ICS
* 3.5mm Earphone Jack, AC Adapter Port, TF Card Slot
* Built in Stereo speakers / Built in Microphone
* Dimenzije: 255*192*12.7mm / 770g
* PRODAJNA CENA: 1499Y = 238$
NEPOTRJENE SPECIFIKACIJE:
- Bluetooth 4.0
- HDMI
- DLP PICO projector integrated
Uradna stran:
http://www.smartdevice.com.cn/
http://shop.smartdevices.com.cn/ten3.html
http://www.smartdevice.com.cn/Information/Events/201202/22-1592.html
Trenutno najugodnejši nakup: = 249$
http://hotmid.com/smartq-ten3-9-7-inch-ips-capacitive-touch-screen-android-4-0-tablet.html
Del debate s tujega foruma o SmartQ tabletih:
The impression Andropos has givende me, is that SmartQ is one of the finest "low end" producer, both when it comes to support and build quality. I have never owned or tried a SmartQ product. I would really like to try the Ten3 myself thought. Having a TI processor under the hood is really promising.
Hopefully the firmwares will be more completed, as oposite to firmwares release by Allwinner and Rockchip. Im sure Texas Instruments (TI) has a better relationship with Google also, which will probobly lead to a working market and other Google apps right out of the box, no tweaking/scripting needed. (Google Market license?)
Tomson
Prispevkov: 119
Pridružen: 21 dec 2010, 23:50
Re: SmartQ TEN3 (DualCore OMAP4430 / GPU: SGX540)
Št. objave:#2  OdgovorNapisal/-a au9879 » 22 feb 2012, 20:41
Kolikor sem jst uspel razbrati iz specifikacij, bo vn prišlo več verzij - konkretno ta iz naslova res ne bo imela hdmi, kar je zame veliko razočaranje:
Uporabniku au9879 so se za prispevek zahvalili:
Tecumseh
au9879
Prispevkov: 52
Pridružen: 13 nov 2011, 16:17
Št. objave:#3  OdgovorNapisal/-a Tomson » 23 feb 2012, 01:26
Hmm... če ta tabela drži bo T20 vseboval HDMI, 16GB, dve kameri in Bluetooth 4.0 za 50€ več, se pravi 230€, medtem ko bo T15 (Ten3) ostal brez teh bonbončkov ... Ko bi le T20 bil še v 4:3 verziji! :) (telih 16:9 me sploh ne prepriča za tablet, se mi zdi surfanje bistveno komfortnejše na 4:3 zaslonu glede na skupno diagonalo)
Tomson
Prispevkov: 119
Št. objave:#4  OdgovorNapisal/-a Tecumseh » 23 feb 2012, 01:46
če bo v sebi imel še projektor sem pripravljen zanj odšteti cca. 350€ :)
pa še en zanimiv prispevek o tablici
če bo res podpiral še windowse potem je vredno počakati na uradni izid :)
Tecumseh
Prispevkov: 49
Pridružen: 05 sep 2010, 17:01
Št. objave:#5  OdgovorNapisal/-a Tomson » 23 feb 2012, 02:09
Kot trenutno izgleda so v decembru ko so prišle ven napovedi za T15 in T20 modela vse skupaj malo pomešali in kar posplošili tale Bluetooth ter dual cameri za TEN3 ki po zgornji tabeli pripada modelu T20.
Hecno mi je da še danes imajo na strani SmartDevices tisto sliko z naslovom TEN3 kjer je razvidna aplikacija za DLP PICO projector ter GPS ko pa danes povsod v predprodaji ni govora niti o bluetoothu niti o GPSu seveda ne o PICOtu, še več, niti njihov najdražji model ne omenja GPSa, tako da res ne razumem čemu na uradni strani dajat neke slikice o zadevah ki jih očitno ni?!
Sicer pa, očitno bo še treba počakat pa se pustit presenetit ...
Tomson
Prispevkov: 119
Št. objave:#6  OdgovorNapisal/-a Tecumseh » 23 feb 2012, 02:16
se strinjam, ne preostane nam nič drugega, kot da čakamo na neko uradno recenzijo, kjer bo videti tablet pc 'v akciji' :)
Tecumseh
Prispevkov: 49
Št. objave:#7  OdgovorNapisal/-a msev » 23 feb 2012, 10:36
Upam da bojo dečkoti dal notr bluetooth in hdmi ;D...ostalo bo že preveč za ta dnar :)
msev
Prispevkov: 27
Pridružen: 03 jan 2012, 01:32
Št. objave:#8  OdgovorNapisal/-a Tomson » 23 feb 2012, 13:14
Za taj dinar bo že bluetooth optimističen! ;)
Tomson
Prispevkov: 119
Št. objave:#9  OdgovorNapisal/-a Tecumseh » 23 feb 2012, 19:41
tale tabletpcmanija je pri meni dobila nove razsežnosti, saj sem sedaj že začel s pomočjo google prevajalnika brati kitajske forume kjer potekajo razprave o tabletih :)
a se to samo meni dogaja, ali pa ima še kdo podobne simptome? :D
trenutno sicer brskam malo po forumu na povezavi
Tecumseh
Prispevkov: 49
Št. objave:#10  OdgovorNapisal/-a Tomson » 25 feb 2012, 17:42
Tomson
Prispevkov: 119
Št. objave:#11  OdgovorNapisal/-a Tecumseh » 25 feb 2012, 17:46
očitno ne bo ravno smartbuy za tak denar
Tecumseh
Prispevkov: 49
Št. objave:#12  OdgovorNapisal/-a Tecumseh » 25 feb 2012, 18:11
kaj pa model s te povezave ?
ima odličen procesor, Android 4.0, podpira Flash 11.1, 10-točkovni IPS display z ločljivostjo 1024x768, dve kameri - front 2.0mp, rear 5.0mp, HDMI, Bluetooth, GPS.
Po podatkih na strani nima reže za dodatno spominsko kartico, kar je pomoje katastrofalna napaka proizvajalca, saj ima vse ostale karakteristike odlične.
Tecumseh
Prispevkov: 49
Št. objave:#13  OdgovorNapisal/-a Tomson » 25 feb 2012, 18:19
Specifikacije so dobre! Edino kar pogrešam je HDMI. Cena tudi ni pretirana ... bo treba malo pobrskat kaj je to za ena firma ker pri teh kitajskih tabletih je na koncu koncev najpomembnejša zanesljivost. Imajo en kup poceni elektronike ki je na papirju odlična potem pa serijsko crkuje po nekaj tednih delovanja.
Sam sem se odločil da če nabavim kitajski tablet mora bit od ene tistih preverjeno zanesljivih firm. Kolikor sem zaenkrat zasledil si po kvaliteti sledijo: Smartq, Teclast ki sta 1A potem pa Onda, Bmorn, Window ...
Tomson
Prispevkov: 119
Št. objave:#14  OdgovorNapisal/-a Tecumseh » 25 feb 2012, 18:24
Tomson napisal/-a:Specifikacije so dobre! Edino kar pogrešam je HDMI. Cena tudi ni pretirana ... bo treba malo pobrskat kaj je to za ena firma ker pri teh kitajskih tabletih je na koncu koncev najpomembnejša zanesljivost. Imajo en kup poceni elektronike ki je na papirju odlična potem pa serijsko crkuje po nekaj tednih delovanja.
pa bi vseeno vzel tudi tablet od enega izmed zgoraj omenjenih proizvajalcev s takimi specifikacijami, če ne bi imel reže za microsd? meni se 16GB zdi premalo, 32 bi že nekako šlo. Mogoče pa podpira priklop zunanjih USB trdih diskov :))
Tecumseh
Prispevkov: 49
Št. objave:#15  OdgovorNapisal/-a Tomson » 25 feb 2012, 18:35
Če bi šlo za dobro firmo pa če bi imel še HDMI bi preživel brez razširitvene kartice, sploh če je za 260€ zraven še Bluetooth in GPS pa dvojedrni procesor ... Očitno je pač očitno da pri kitajcih kljub 1000 različnim modelom in proizvajalcem zaenkrat niti eden nima vsega kar bi si človek želel. Imajo pa zato sprejemljivo ceno! ;)
Tomson
Prispevkov: 119
Št. objave:#16  OdgovorNapisal/-a Tecumseh » 25 feb 2012, 20:46
mogoče je pa dogovor kitajskih proizvajalcev tak. iz tega razloga se prodaja porazdeli na vse proizvajalce in kitajsko gospodarstvo cveti, dokler vsa ostala gospodarstva propadajo - očitno se uresničuje Nostradamusova prerokba, da bo rumena rasa v prvi polovici stoletja zavladala na planetu :)
Tecumseh
Prispevkov: 49
Št. objave:#17  OdgovorNapisal/-a kmetek » 26 feb 2012, 12:37
In kdo je kriv? Mi sami, ker vsi radi poceni kupimo. Vsi jebeni artikli so MADE in FUCKING CHINA oziroma 90%.
Pa vsi požrešni direktorji podjetij, kjer niso zadovoljni z milioni €.
Vse bi lahko po svetu proizvajalo tudi tablice v evropi, vse bi se dalo, samo manj požrešenosti kljub dražjemu delavcu v evropi.
Bi se pa sčasoma poznalo na gospodarstvu itd. Tukaj krivim vlade, ki to ne spregledajo.
kmetek
Prispevkov: 2201
Pridružen: 08 jun 2010, 06:05
Kraj: Kranj
Naprava: LG NEXUS 5
Št. objave:#18  OdgovorNapisal/-a Tomson » 26 feb 2012, 15:39
kmetek napisal/-a:In kdo je kriv? Mi sami, ker vsi radi poceni kupimo. Vsi jebeni artikli so MADE in FUCKING CHINA oziroma 90%.
Ne vem po kakšni logiki bi bili krivi potrošniki če raje kupimo 50% cenejšo stvar. Trg pač deluje po principu konkurenčnosti. Če evropa ni konkurenčna za to nismo krivi potrošniki ampak kot si omenil podjetja sama oziroma njihova vodstva. Sicer niso imela izbire, zaradi konkurenčnosti kar nas pripelje do glavnega krivca - kot si že omenil, POHLEPA! In pohlep nas je pripeljal do trenutka ko se oziramo proti Kitajski in iščemo cenejše alternative. Sicer kot sam vidim je to trenutek v času ko so Kitajci tehnološko začeli izkoriščati svoje znanje, vemo pa tudi kam to pelje. Čez 5-10let kitajska ne bo več poceni. Takrat se bomo pač ozirali proti Afriki, itd. Če bi globalizem ne bil tako precenjen, bi evropa lahko cvetela v svojem gospodarstvu in potrošništvu, tako pa kot že rečeno to ni mogoče, zaradi pohlepa.
Tomson
Prispevkov: 119
Št. objave:#19  OdgovorNapisal/-a dre » 26 feb 2012, 17:45
Mene pa tele kitajske stvari čim manj fascinirajo tudi, če so cenejše.Ker vse skupaj ni neke kvalitete, kaj piše je ena plat samo delovanje pa druga.
dre
Pridružen: 27 jan 2012, 15:36
Št. objave:#20  OdgovorNapisal/-a teo » 26 feb 2012, 19:24
Govoriš ti to iz prakse??? Če ja, daj primer!
teo
Prispevkov: 458
Pridružen: 09 jan 2012, 20:57
Naprava: samsung galaxy s8+
Št. objave:#21  OdgovorNapisal/-a Tomson » 26 feb 2012, 20:30
dre napisal/-a:Mene pa tele kitajske stvari čim manj fascinirajo tudi, če so cenejše.Ker vse skupaj ni neke kvalitete, kaj piše je ena plat samo delovanje pa druga.
Odvisno kje kupiš in predvsem kaj kupiš. Na kitajskem je en kup ponaredkov in res slabo narejenih zadev, ki delajo zelo kratek čas ali pa sploh ne. Če pa se malo pozanimaš in kupiš kos elektronike od priznanih proizvajalcev na kitajskem, pa še vedno dobiš 80-90% kvalitete izdelkov iz zahoda za 50% cene. Mislim da je to še vedno ugoden deal.
Tomson
Prispevkov: 119
Št. objave:#22  OdgovorNapisal/-a kmetek » 26 feb 2012, 22:30
Tomson: "krivi" smo do te mere, ko to podpiramo = kupujemo. Prvo so pa kriva podjetja in njihov pohlep...
Na končni znesek artikla, če bi isti izddelek proizvedli v EU ali USA bi bila razlika pomoje ničelna skoraj, samo manj milionov za pohlep.
Kitajska je nevarnost za celotni svet. Ma kakšna Afrika lepo vas prosim, oni so še 1000 let nazaj. Kako ti bo en zumbo delal?
kmetek
Prispevkov: 2201
Kraj: Kranj
Naprava: LG NEXUS 5
Št. objave:#23  OdgovorNapisal/-a Tomson » 27 feb 2012, 02:14
Afrika je prispodoba za Kitajsko pred 20leti ali še manj ... te popolnoma razumem kaj hočeš povedat ampak kupcev ne moreš krivit in konec, me nobeden ne prepriča da bom imel slabo vest, ker kupim nekaj od kitajca. Če npr. evropa tega ne more ponudit za vsaj podobno ceno. (sicer pa isti kitajec itak izdeluje tudi zahodne produkte ki jih lahko kupim za 50% višjo ceno zaradi firme in nekaj členov v verigi!! Razumem da je neka zadeva 20% dražja, za 50% se pa že počutim neumno. Tukaj bi tvojo besedo da so kupci krivi zamenjal z neumni da podpirajo tako drago industrijo ki je očitno lahko cenejša. Ko bo evropska oz. zahodna politika oz. cel razviti svet ugotovil kakšno uslugo so si naredili z selitvijo proizvodnje na kitajsko (kar so že ugotovili - to je tudi eden od razlogov gospodarsko-ekonomske-moralno-etične krize dandanes) in bodo dejansko začeli razmišljati v smeri izboljšanja situacije in selitev proizvodnje nazaj domov, ter tako ustvarili prepotrebna delovna mesta za obuditev gospodarske rasti in zaposlitev vedno večjega števila nezaposlenih, ne pa jamranja (kot v tvojem primeru - pa brez zamere) da ljudje vedno več kupujejo poceni zadeve, slabše kvalitete. Potem se bom tudi sam potrudil in kupoval doma. Danes je pač tako da tabličnega računalnika za 700€ si ne morem privoščit (čeprav me Prime zelo mika) lahko pa stisnem tistih 200€. Seveda pa bom za 200€ želel čim več zato bom namesto mpmana poizkusil srečo pri kitajcih ... Simple as that!
Tomson
Prispevkov: 119
Št. objave:#24  OdgovorNapisal/-a darkside » 29 feb 2012, 11:31
js pa sploh ne kupujem kitajcev.. ne podpiram tega sranja.
sicer povsod piše made in china samo če je na kitajskem samo sestavljeno oz. izdelano točno tako kot reče proizvajalec potem ja, drugače pa te čunga lunga stvari ki so orginal njihove ne kupujem
sem se enkrat opekel in se ne mislim več.
se pa od takrat dalje držim reka da nisem tako bogat da bi kupoval poceni.
Prispevkov: 12307
Prejete zahvale: 1653
Št. objave:#25  OdgovorNapisal/-a Tomson » 29 feb 2012, 12:15
Tudi sam še nisem nabavljal tej kitajskih stvari, čeprav me mika, da bom vsaj vedel iz prve roke kako se lahko primerja z nam znanimi proizvajalci ...
Tomson
Prispevkov: 119
