Nvidia Shield Tablet
18 prispevkov
• Stran 1 od 1
IMPOSSIBLY ADVANCED MOBILE PROCESSOR
Tegra K1 is the first-ever console-class mobile processor, giving you full support for PC-class gaming technologies like DirectX 12, OpenGL 4.4, and tessellation. Plus, it's the first mobile processor to run Unreal Engine 4, Epic's latest game engine for powering next-gen games.
5 MEGAPIXEL CAMERAS
With front and rear-facing 5 MP cameras, the SHIELD tablet is great for capturing life’s big moments and sharing them with video chat. It also comes preloaded with the Camera Awesome app to give all your photos just the look you’re going for.
EXPANDED CONNECTIVITY
Stay connected with 802.11n 2x2 MIMO Wi-Fi for fast PC game streaming and optional LTE high-speed cellular connectivity. Includes a Mini-HDMI port, Bluetooth 4.0, and Micro-USB 2.0, 3.5 mm audio jack. Free up memory by moving your app and game files to an external microSD card.
NVIDIA GAMESTREAM™
Stream games from your GeForce GTX-enabled PC and play them on SHIELD tablet using the SHIELD wireless controller with ultra-low latency.
NVIDIA SHADOWPLAY™
NVIDIA ShadowPlay seamlessly records your greatest gaming moments or streams your game action to Twitch as you play.
GAMEPAD MAPPER
Add gamepad support to native touch Android games so you can play thousands of games using the SHIELD wireless controller. Use NVIDIA’s default game profiles or create your own!
Processor
• NVIDIA® Tegra® K1 192 core Kepler GPU, 2.2 GHz Quad Core A15 CPU, 2GB RAM
Display
• 8-inch 1920x1200 multi-touch IPS display
Audio
• Integrated stereo speakers with built-in microphone
Storage
• 16 GB
Wireless
• 802.11a/b/g/n 2x2 Mimo 2.4 GHz and 5 GHz Wi-Fi
• Bluetooth 4.0 LE
• GPS / GLONASS
Connectivity
• WiFi
• Mini-HDMI 1.4a output
• Micro-USB 2.0 with host and device support
• Micro SD Card, up to additional 128GB
• 3.5 mm stereo headphone jack with microphone support
Motion Sensors
• 9-axis (G-sensor, compass, gyro)
Audio
• Front facing stereo speakers Dual bass reflex port
Gaming Features
• SHIELD wireless controller compatible
• NVIDIA GameStream
• NVIDIA ShadowPlay
• GRID Cloud Gaming Beta
• Console Mode
• Gamepad Mapper
Cameras
• Front: 5MP HDR; Back: 5MP auto focus HDR
Video Features
• 4K Ultra-HD Ready
Stylus
• DirectStylus 2 with 3D Paint (Included)
Software Updates
• SHIELD software upgrades directly from NVIDIA
Battery
• 19.75 Watt hour Lithium ion
Weight and Size
• Weight: 13.7oz / 390g
• Height: 8.8in / 221mm Width: 5.0in / 126mm Depth: 0.36in / 9.2mm
Operating System
• Android KitKat OS
dsapac - VIP
- Prispevkov: 1378
- Prejete zahvale: 239
- Naprava: Android Box
Re: Nvidia Shield Tablet
Universal Android Root Guide 4.4.0+
1. Omogočite Unknown Source na vaši napravi.
Klikni Settings, potem Security, potem “Unknown Sources”
2. Dolpoteg TowelRoot, a kickass hack by GeoHot.
TowelRoot
3. Install TowelRoot in ga zaženi.
Klikni “make it ra1n”
TowelRoot omogoči instalacijo Superuser aplikacije.
Jaz vedno uporabljam SuperSu.
Instalacija custom recovery
Dolpoteg Flashify.
Flashify
Tole je zelo uporabna aplikacija,omogoča flashanje boot.img in recovery.img brez odklenjenega bootloaderja!
CWM Recovery for Nvidia Shield Tablet
PhilZ Recovery for Shield Tablet
Ko si dolpotegnete željeni recovery zaženite Flashify pojdite v download folder in flashajte recovery.
Dolpoteg Quick Boot (Reboot)
Quick Boot (Reboot)
Z tole aplikacijo najlažje bootate napravo v recovery ali bootloader. Napravo zaženite v recovery. Ko se naprava zažene v recovery:
*Wipe --> Factory Reset (Data, Cache, and Dalvik Cache)
*Flash ROM
*Flash Gapps
*Reboot
Priporočam VanirAOSP ker je trenutno najbolj posodobljen firmware.
VanirAOSP
TowelRoot
Dolpoteg Flashify.
Flashify
Quick Boot (Reboot)
*Flash ROM
*Flash Gapps
*Reboot
VanirAOSP
dsapac - VIP
- Prispevkov: 1378
Ker ima naprava zunanjo pomnilno enoto sem vstavil 32GB class 10 micro sd kartico. Ker imam napravo root-ano sem uporabil aplikacijo Folder Mount in sem si prenesel večje datoteke na zunanjo kartico.
Tukaj še enkrat prilagam screenshot nekaterih iger katere imam instalirane.
dsapac - VIP
- Prispevkov: 1378
GLTools (graphics optimizer)
GLTools is a custom OpenGL driver (proxy), that is compatible with any known OpenGLES 2.0-compatible GPU + ARM processor, x86 processors are not supported (Galaxy Tab 3 for example). If you still don't understand, what this app is, the closest known analog is Chainfire3D.
Features list:
- Change resolution and rendering bitness in any app, even if it doesn't support that by default.
- Change GPU name and enjoy enhanced graphics even on a noname low-end GPU.
- Take full control over textures: now you can decompress/recompress them (even if your GPU doesn't support that texture format) and resize. Note that decompression feature is available only if you'll install a plugin (internet is required to do that)
- Optimize shaders on-the-fly for optimal performance (the same optimizer is used in Unity3D engine by default)
- Enable MSAA or CSAA in any app to improve graphics quality (make sure that your GPU supports that)
- Measure gained performance with a nice onscreen FPS counter (or you can output FPS information to Logcat if you are a pro)
GLTools is 100% safe if you have a custom recovery installed (and you didn't disable backup in GLTools install dialog), if you'll find it non-working, you can just flash uninstall_gltools.zip in recovery and email me with details (or request a refund).
Features list:
dsapac - VIP
- Prispevkov: 1378
FolderMount [ROOT]
Today some apps store big files over the internal SD card (e.g. games, podcasts, offline RSS content, pictures, videos, offline navigation software). Typically users have a small internal sd card size (~16GB) while the external SD is a lot bigger (~32-64GB). Most of these apps users download from the Play Store save their application data in the internal sdcard by default and don't have an option to use the external SD card to store data so they starve your internal SD card memory. FolderMount is the solution to this issue. This app has the ability to link folders in your internal sdcard to folders in your external sdcard thereby populating the internal sdcard folders with content that really exists in the external card. This helps us free space and have multiple games/apps with big data stored simultaneously without the need to uninstall. For Nexus devices with no external sdcard, this application should help link folders to a usb flash drive for example.
Features of FolderMount:
* Mount internal SD card folders to external SD folders.
* Move content from internal to external when a pair is added. (Dialog prompt)
* Support for Android 2.3 - 4.2.2.
* Holo themed throughout and an intuitive GUI design.
* It will check SDCARD mount status and remount if necessary.
Howto
* Add a folder pair. Source is the internal sdcard and destination is your extSdCard
* After adding, FM will offer to move the files for you. Click yes.
* Wait until the move operation is done then click on the PIN. If PIN turns green, you're all set.
* The files will exist in both the source and destination after mounting. This is expected and is normal. The files you see in your internal sdcard actually reside in your external sdcard now and if you "unpin" the pair, you'll see that your internal sdcard is empty again.
Howto
dsapac - VIP
- Prispevkov: 1378
Kako najceneje do te tablice? Koker vem je v slo sploh ne prodajajo.
- Nyrix
- Prispevkov: 411
- Pridružen: 06 sep 2011, 08:08
- Prejete zahvale: 34
- Naprava: OnePlus 3
- Nyrix
- Prispevkov: 411
Ali je res tako slabo sestavljena , da v kotih ohisja poka?
Poslano z mojega HTC One z uporabo Tapatalk
Mene samo zanima ali se jo da kupiti samo po spletu, ali pa jo je mogoce kupiti v kaki trgovine v Sloveniji, Italiji ali pa na Hrvaškem? Hvala
- iRokOfficial
- Prispevkov: 2
- Pridružen: 13 maj 2015, 18:10
Jaz sem si jo naročil preko spleta (ebay) Tablica ponuja toliko možnosti. Bom jutri kaj več napisal ter prilimal kake sličice. Ker danes imam obveznosti v Rakičanu zaradi dneva Slovenske vojske.
- Uporabniku dsapac so se za prispevek zahvalili:
- iRokOfficial
dsapac - VIP
- Prispevkov: 1378
Ok hvala
- iRokOfficial
- Prispevkov: 2
Kolk vas ma kaj tole tablico? Se jo da uporabljat kot konzolo? Da bi jo naprimer priklopil na 4k tv in igral gor preko kontrolerja od nvidie? Pa katere igre se da imet gor? S kakšnim zamikom deluje streaming iz kompa prek nvidia hub?
Poslano z mojega LG-H815 z uporabo Tapatalk
- Dauk
- Prispevkov: 7
- Pridružen: 22 sep 2014, 14:10
tablica ima mini hdmi output tako da brez problema priklopiš.
igranje preko kontrolerja bi moralo iti glede na to da ga prodajajo poleg kot opcijski dodatek
igre ki jih lahko igraš: https://play.google.com/store (ima android 5.0 tako da vse kar so android igre)
za zamik ne vem kakšen je.
da bi uporabljal kot konzolo. kako to misliš? pač nastavil igro na tablici, povezal na pc in preko gamepada igral? seveda bi moralo iti. to jaz delam na telefonu le da na tv ni povezan ker ni hdmi output oz. ni hml podpore (preko neta bi pa zaradi slabe linije bilo preveč zamika)
- Prispevkov: 12307
- Prejete zahvale: 1653
Mislis da bi blo boljse ce kupim shield tablet al shield tv? Kaj je bolj primerno igranju iger in ogledu filmov na tvju?
- Dauk
- Prispevkov: 7
Tablet je boljši za igre zaradi polnega dostopa do google playa, dočim je pa android tv boljši za oglede filmov in slabši zaradi oknjenega nabora aplikacij.
Btw, pa tudi vse igre na tablet-u nimajo podprte opcije za igralni plošček in je potrebno uporabiti miško in tipkovnico.
18 prispevkov
• Stran 1 od 1
