Samsung Galaxy Note10 / Note10+ plus
Samsung je 7.8.2019 v New Yorku predstavil Galaxy Note10 in Note10 + plus
GALAXY NOTE10
Dimenzije: 151 x 71.8 x 7.9 mm
Teža: 168 g (5.93 oz)
IP68 dust/water proof (up to 1.5m for 30 mins)
Stylus (Bluetooth integration, accelerometer, gyro)
DISPLAY: Type Dynamic AMOLED capacitive touchscreen, 16M colors
6.3 inches, 98.6 cm2 (~90.9% screen-to-body ratio)
1080 x 2280 pixels, 19:9 ratio (~401 ppi density)
HDR10+
Chipset: Exynos 9825 (7 nm) - EMEA/LATAM
Qualcomm SDM855 Snapdragon 855 (7 nm) - USA/China
CPU: Octa-core (2x2.73 GHz Mongoose M4 & 2x2.4 GHz Cortex-A75 & 4x1.9 GHz Cortex-A55) -
EMEA/LATAM
Octa-core (1x2.8 GHz Kryo 485 & 3x2.4 GHz Kryo 485 & 4x1.7 GHz Kryo 485) - USA/China
MEMORY: Card slot No
Internal 256 GB, 8 GB RAM
CAMERA: Zadnja:
Triple: 12 MP, f/1.5-2.4, 27mm (wide), 1/2.55", 1.4µm, Dual Pixel PDAF, Dual OIS
12 MP, f/2.1, 52mm (telephoto), 1/3.6", 1.0µm, PDAF, Dual OIS, 2x optical zoom
16 MP, f/2.2, 12mm (ultrawide), 1.0µm
LED flash, auto-HDR, panorama
Video: 2160p@30/60fps, 1080p@30/60/240fps, 720p@960fps, HDR10+, dual-video rec., stereo
sound
rec., gyro-EIS & OIS
SELFIE CAMERA:
Single: 10 MP, f/2.2, 26mm (wide), 1.22µm, Dual Pixel PDAF
Dual video call, Auto-HDR
Video: 2160p@30fps, 1080p@30fps
3.5mm jack NE
Bluetooth: 5.0, A2DP, LE, aptX
BATERIJA: Non-removable Li-Ion 3500 mAh battery
Charging Fast battery charging 25W
USB Power Delivery 3.0
Fast Qi/PMA wireless charging 20W
Power bank/Reverse wireless charging 9W
Barve: Aura Glow, Aura White, Aura Black, Aura Pink, Aura Red
Verzije: SM-N970F (Europe); SM-N970F/DS (Global); SM-N970U (USA); SM-N970U1 (USA unlocked); SM-N970W (Canada); SM-N9700/DS (LATAM, Brazil, China); SM-N970N (South Korea)
GALAXY NOTE10
HDR10+
EMEA/LATAM
CAMERA: Zadnja:
sound
SELFIE CAMERA:
3.5mm jack NE
Re: Samsung Galaxy Note10 / Note10+ plus
GALAXY NOTE10 + PLUS
Dimenzije: 162.3 x 77.2 x 7.9 mm
Teža: 196 g
Size: 6.8 inches, 114.0 cm2 (~91.0% screen-to-body ratio)
Resolution: 1440 x 3040 pixels, 19:9 ratio (~498 ppi density)
HDR10+
CPU: Octa-core (2x2.73 GHz Mongoose M4 & 2x2.4 GHz Cortex-A75 & 4x1.9 GHz Cortex-A55) - EMEA/LATAM
MEMORY: Card slot microSD, up to 1 TB (uses shared SIM slot) - dual SIM model only
Internal: 256/512 GB, 12 GB RAM
KAMERA:
Zadnja: Quad 12 MP, f/1.5-2.4, 27mm (wide), 1/2.55", 1.4µm, Dual Pixel PDAF, Dual OIS
TOF 3D VGA camera
Video: 2160p@30/60fps, 1080p@30/60/240fps, 720p@960fps, HDR10+, dual-video rec., stereo sound rec., gyro-EIS & OIS
SELFIE KAMERA: Single 10 MP, f/2.2, 26mm (wide), 1.22µm, Dual Pixel PDAF
Video: 2160p@30fps
3.5mm jack NE
BATERIJA: Non-removable Li-Ion 4300 mAh battery
Charging Fast battery charging 45W
Barve: Aura Glow, Aura White, Aura Black, Aura Blue
Verzije: SM-N975F (Europe); SM-N975F/DS (Global); SM-N975U (USA); SM-N975U1 (USA unlocked); SM-N975W (Canada); SM-N9750/DS (LATAM, Brazil, China); SM-N975N (South Korea)
Samsung je predstavil tudi različico s podporo mobilnim omrežjem pete generacije 5G, ki pa je po specifikacijah skorajda identična 4G/LTE verziji.
https://www.gsmarena.com/compare.php3?i ... hone2=9732
https://www.samsung.com/si/smartphones/galaxy-note10/
Teža: 196 g
HDR10+
KAMERA:
TOF 3D VGA camera
Video: 2160p@30fps
3.5mm jack NE
Ali mogoče kdo ve če se ga da že kje v živo ogledat pa mal probat ?
Presenetljivo, da je cena recmo na Telekomu od 33.50€x24m in to + verzija 256gb/12gb, medtem ko sem jaz dal za S10+ 35.50€x24m. Ponavadi je bila Note serija vedno dražja, sedaj pa glih obratno. Zgleda, da nudi Telekom ob nakupu Note serije boljšo subvencionirano ceno kot pa pri S seriji na začetku prodaje. Če bi vedel da bo bil Note cenejši nakup, bi počakal z nakupom in defenitivno vzel Note 10+, čeprav sem tut z S10+ izredno zadovoljen.
Drugače pa tale Note 10+ prava mašina, ni kej.... [SMILING FACE WITH OPEN MOUTH] Pa presenečenje je, da so pri Note seriji uporabili boljši hardware kot pri S seriji. Ponavadi so uporabili isti hardware v istem letu. 5g verzije pa verjetno pri nas zaenkrat ne bo v prodaji, glede na to, da pri nas o 5g še ni ne duha ne sluha....
- frenk27
- Prispevkov: 447
- Kraj: 1310 Ribnica
- Prejete zahvale: 28
To je cena za prednarocilo, potem bo cca 37€ na mesec.
de marco - AncientDroid
- Prispevkov: 2035
- Prejete zahvale: 154
- Naprava: Samsung galaxy note 8
Ahaa... se mi je zdelo, da je čudno da bi bila nižja cena Nota 10+ od S10+.... Se pa ga zdaj splača uzet potem za to ceno, dobiš orng mašino. Ve kdo recimo za primerjavo, kateri proc je jači Exynos 9825 ali Snapdragon 855? Hvala
- frenk27
- Prispevkov: 447
Na telekomu na enakem paketu je drazji note 9, 512gb od nota 10 plus. Neverjetno vendar resnicno.
Zadnjič spremenil Picaso, dne 12 avg 2019, 21:41, skupaj popravljeno 1 krat.
Razlog: za oglase je tema mali oglasi!
- rp
- Prispevkov: 14
- Pridružen: 15 sep 2016, 14:38
Kar je se bolj neverjetno je to, da A1 zopet še nima znanih cen po paketih za Note 10/+, ki da bodo znane šele tip pred prodajo. Vedno ena in ista zgodba.
Sent from my SM-N960F using Tapatalk
- doctor78
- Prispevkov: 255
- Pridružen: 10 dec 2013, 12:55
- Prejete zahvale: 20
- Naprava: SM-950F
Troba napisal/-a:Ali mogoče kdo ve če se ga da že kje v živo ogledat pa mal probat ?
V Cityparku, trgovina Samsung v 1.nadstropju.
Ali ima kdo kakšne informacije .. se splača vzet Note 10+ v prednaročilu ali bo spet prej kot čez en mesec od začetka prodaje boljša ponudba? (tako kot je bilo pri Mate 20 pro pri A1, ko si v prednaročilu dobil wireless charger, čez tri tedne so pa zraven dajali uro.)?
To je pa že šloganje... Nihče nima steklene kugle...
- piromanček
- Prispevkov: 166
- Pridružen: 30 jan 2015, 07:21
- Prejete zahvale: 17
A res, sem mislu da jo ima še kdo
Verjetno kdo, ki dela na samsungu ali A1 tudi bere ta forum in ima kakšne insiderske informacije. Tako kot je nekdo napovedal takrat, da tudi huawei pripravlja akcijo z uro.
Zadnjič spremenil DomenH, dne 13 avg 2019, 11:11, skupaj popravljeno 2 krat.
Dvomim da bo kdo šel bilo kaj povedat če tudi kaj ve
Deky_ - AncientDroid
- Prispevkov: 845
- Pridružen: 23 avg 2010, 10:03
- Prejete zahvale: 90
- Naprava: Samsung Galaxy S9 plus
Hmm, kaj ni bilo rečeno, da bo dostava 23? Sedaj pa na Telekomu piše 19. To bi bilo super
Ne piše 19, ampak od 19-ga dalje
Mogoče pri njih pošta rabi 5 dni ...
Javite telekomovci, če boste dobili pred 23-im, ko je baje uraden izid, al' so to spet tk igrice pod pasom za pridobivanje kupcev !?
- s5en3besman
- Prispevkov: 182
- Pridružen: 20 dec 2014, 16:27
- Prejete zahvale: 25
Vsekakor vam želim, da ga dobite prej! Vsi ga že nestrpno čakamo.
Sam sem ga naročil v BB in bo sigurno naslednji petek.
- s5en3besman
- Prispevkov: 182
Sem videl , da imajo prodajalci vsi akcijo za 100 eur v prednaročilu.
Bigbang ter mimovrste pri vpisu kode dobiš namesto 949 eur za Note 10 849 eur.
Dobavljivost 27. avgusta.
Ne vem ali grem kar takoj v akcijo ali počakam na Bolho in od nekoga s vezavo.... jeba tale "odvisnost".
Mi je pa zelo, zelo všeč mali NOTE...
Tole sem hotel dogo časa... nimam rad velike telefone.
Sem ga malo stestiral na telekomu ter v Bigbangu... nisem si mislil da mi bo všeč, sploh zaradi kamere... ampak super.....
- Prispevkov: 2987
- Prejete zahvale: 274
- Naprava: NOTE10/Garmin645M
Dobro se sliši mali Note. Še nedaleč nazaj je bila ta velikost cegu.
- s5en3besman
- Prispevkov: 182
Kakor koli, še vedno je cegu...:-)
- piromanček
- Prispevkov: 166
Nekaj Apple Samsung trikov:
Ja, morda male zadeve za nekoga, spet velike za druge, pa vendar... Konec koncev stanejo ti sodobni flagship mobiteli kar nekaj novcev. Za tak denar si upravičeno pikolovski.
Note serija je pri Samsungu vedno veljala za telefon ki zmore VSE. No, od N10 dalje očitno VSE zmore le za 150€ dražja verzija, pa še potem le z zvezdico in drobnim tiskom.
Sicer pa mi je zelo všeč, da so zmanjšali preluknjanost ekrana in da so luknjo pomaknili na sredino.
- Na N10+ so končno dodali res hudo 45W polnjenje, ampak seveda Apple style: polnilec za tako hitro polnjenje je potrebno kupiti posebej. Ker 1100€ je res premalo, da dodaš boljši polnilec...
- N10 očitno pri Samsungu več ni flagship, ker je letos dobil resolucijo ekrana iz časa N3(!). Očitno je to-to dan danes pri Samsungu, če plačaš "zgolj" 950€ in ne 1100€. Zanimivo... precej spominja na zgodbo o ekranu na cenejšem iPhone XR. Vsaj OLED so ohranili.
- Odstranili so 3.5mm jack. Nekako pričakovano glede na trende, pa vendar mislim da je tukaj Apple kriv s svojim "pogumom" za ta trend in ne dejansko pomanjkanje prostora v mobitelih. LG je sedaj edini?
Aja... USB-C na 3.5mm jack dongle ni priložen. Enaka zgodba kot pri N10+ polnilcu, da se ne bom ponavljal.
- Prispevkov: 270
- Prejete zahvale: 46
- Naprava: Pixel 3 XL, Fossil gen 5, Pixel C
Se pravi ti dodatki, plus zaščita ekrana in etui dvigne ceno še na + cca 100€. Je skoraj neizbežno.
Jabolki pada prodaja, tudi tukaj lahko pride do tega. Morda ne kratkoročno... Dolgoročno pa...kdo bi vedel....?
- piromanček
- Prispevkov: 166
[OK HAND SIGN]
- Prispevkov: 2035
