Samsung Galaxy Note 9
Note9
Dimenzije: 161.9 x 76.4 x 8.8 mm
Teža: 201 g
S Pen
Dimenzije: 5.7 x 4.35 x 106.37 mm
Teža: 3.1 g
Display
6.4" Quad HD+ Super AMOLED (2960x1440)
516 ppi
*Screen measured diagonally as a full rectangle without accounting for the rounded corners.
*Default resolution is Full HD+ and can be changed to Quad HD+ in Settings.
*Infinity Display: a near bezel-less, full-frontal, edge-to-edge screen.
S Pen
Bluetooth enabled
Super capacitor: 30 minutes of standby with 40 seconds of charging
Pressure levels: 4096
Pen Tip diameter: 0.7 mm
IP68
Live message
Samsung Notes
Screen off memo
Smart select
Screen write
Translate
Bixby Vision
Glance
Magnify
PENUP
Coloring
*S Pen remote function reaches about 10 meters in an open space. Performance subject to circumstances.
*S Pen battery life may vary based on usage.
*IP68 rating is based on test conditions for submersion in up to 1.5 meters of freshwater for up to 30 minutes. Rinse residue/dry if wet.
Front Camera
8MP AF sensor
Sensor size: 1/3.6"
Pixel size: 1.22µm
Sensor ratio: 4:3
FOV: 80˚
F1.7 aperture
Selfie focus
Selfie
Wide selfie
Rear Dual Camera
Wide-angle
Super Speed Dual Pixel 12MP AF sensor
Sensor size: 1/2.55"
Pixel Size: 1.4µm
Sensor ratio: 4:3
FOV: 77˚
Dual Aperture: F1.5 mode/ F2.4 mode
Telephoto
12MP AF sensor
Sensor size: 1/3.4"
Pixel Size: 1.0µm
Sensor ratio: 4:3
FOV: 45˚
F2.4 aperture
Dual OIS (Optical Image Stabilization)
Optical zoom at 2x
Digital zoom up to 10x
Scene Optimizer
Flaw Detection
Live Focus with bokeh filters (background blur effect)
Dual capture
Panorama
Auto/Pro
Super Slow-mo
AR Emoji
Hyperlapse
*Scene optimizer supports 20 modes: Food, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text.
*Accuracy of Scene Optimizer may differ depending on shooting conditions including multiple subjects, being out of focus, or moving subjects.
*Accuracy of Flaw Detection may differ depending on surrounding conditions or subject.
*Blink and blur detection works best when there are three or fewer people in the frame, 1.5 meters or closer to the camera.
*Lens smudge and backlighting detection notifies once every 24 hours if flaw is detected.
*AR Emoji may only be sent with apps supporting GIF format.
*Super Slow-mo only supports HD resolution. In single manual mode, video is approximately 0.4 seconds of recording and 12 seconds of playback at 960 fps. In other modes, video is approximately 0.2 seconds of recording and 6 seconds of playback (with up to 20 shots in multi taking mode).
Front & Rear Camera
VDIS (Video Digital Image Stabilization)
HDR (High Dynamic Range)
Full view
Floating camera button
Flaw Detection
AR Emoji
Motion photo
Filters
Stamps
Grid line
Location tags
Timer
Quick launch
Video Recording
4K video recording at 30 fps or 60 fps
QHD video recording at 30 fps
1080p HD video recording at 30 fps or 60 fps
720p HD video recording at 30 fps
Super Slow-mo video support 720p at 960 fps
Slow Motion video support 1080p at 240 fps
Hyperlapse video support 1080p
High CRI LED Flash
Continuous autofocus video
Face detection
Tracking AF
Take 9.1-megapixel still photos while recording 4K video
Playback zoom
Video location tags
Baterija: 4000mAh
Polnenje:
Fast Charging compatible on wired and wireless
*Wired charging compatible with QC2.0 and AFC
*Wireless charging compatible with WPC and PMA
Omrežje in povezljivost:
Enhanced 4x4 MIMO, 5CA, LAA, LTE Cat.18
*May differ by country and carrier.
Wi-Fi 802.11 a/b/g/n/ac (2.4/5GHz), VHT80 MU-MIMO, 1024QAM,
Bluetooth® v 5.0 (LE up to 2Mbps), ANT+, USB Type-C, NFC, Location (GPS, Galileo, Glonass, BeiDou)
*Galileo and BeiDou coverage may be limited. BeiDou may not be available for certain countries.
AP
10㎚ 64-bit Octa-Core Processor
※2.8GHz + 1.7GHz (Maximum Clock Speed, Performance Core + Efficiency Core)
※2.7GHz + 1.7GHz (Maximum Clock Speed, Performance Core + Efficiency Core)
Spomin: 6GB RAM/128GB ali 8GB RAM/512GB
*8GB RAM models come with 512GB internal storage only. 6GB RAM models come with 128GB internal storage.
*Available internal storage may vary depending on pre-installed software.
Expandable Memory & SIM Card
-Single SIM model: one Nano SIM and one MicroSD slot (up to 512GB)
-Dual SIM model (Hybrid SIM slot): one Nano SIM and one Nano SIM or one MicroSD slot (up to 512GB)
*Availability of Dual SIM may vary by country and carrier.
*MicroSD card sold separately. Availability of 512GB MicroSD may differ by country and manufacturer.
OS
Android 8.1 (Oreo)
Povzeto iz:
https://www.samsung.com/global/galaxy/g ... te9/specs/
https://www.a1.si/galaxy-note-9
https://www.telekom.si/zasebni-uporabni ... nocno-crna
https://www.samsung.com/si/smartphones/galaxy-note9/
Re: Samsung Galaxy Note 9
Mamljiva mašinca, moram rečt, pa tut cena se mi ne zdi pretirana, glede na ceno Note 8. Razmišljam o menjavi, da bi mojega Note 4 zamenjal za tole zverinco
- frenk27
- Prispevkov: 523
- Kraj: 1310 Ribnica
Lahk rečemo, da so dandanes vsi telefoni precenjeni, ampak Note9 je verjetno edini za katerega se splača stegnit "jurja" al' pa malo počakati, da cene padejo. Saj bodo verjetno kar hitro, sam da N9 izide, se bo že začelo govoriti o N10
- s5en3besman
- Prispevkov: 204
- Pridružen: 20 dec 2014, 16:27
- Prejete zahvale: 30
Hvala Picasso da si odprl temo, upam da ga dobim drug teden potem pa diskusija...
- Rast
- Prispevkov: 334
- Prejete zahvale: 17
- Naprava: GEAR S3, NOTE 8, NOTE 9, NOTE 10+, S22U
Upam da ga v petek dostavijo in da vidmo zverino...
- King1
- Prispevkov: 132
- Pridružen: 07 apr 2013, 09:08
- Prejete zahvale: 18
- Naprava: S22 Ultra nažalost
Prevzel, se fila zdaj, pol pa da vidimo, če so spremembe napram N8 vredne slabega petstotaka.
- Uporabniku s5en3besman so se za prispevek zahvalili:
- Mtd
- s5en3besman
- Prispevkov: 204
Ni kaj dosti za napisati, je N8 na steroidih, menjava iz N8 na N9 sigurno ni racionalna, vendar tistim, ki pomeni malček širši zaslon, boljša baterija in BT-Spen, pa še kaj bi se našlo, zamenjava niti ni tako pregešno dejanje.
So pa telefoni dandanes več ali manj vsi kar dobri in blizu vsak sebi, je pa Note serija še vedno ena najbolj, če ne najbolj doteranih in vsestranskih serij, s katero tudi hajter Samsunga ne bi bil razočaran!?
- s5en3besman
- Prispevkov: 204
No danes sem ga tudi jaz dobil, ga nastavljam, malo testiram ....
Naletel pa sem na eno težavico. V diskusiji za moj NOTE 8 sem v videu videl tisto napravico za dodatno simko ob hkratni uporabi SD kartice. Sem kupil, instaliral in je delovalo, 2 simki in SD hkrati.
Sedaj na novenm NOTE 9 sem spet lepo instaliral ampak ne, pravi mi da je nekaj tujega v reži za simko in me ne spusti dalje. Skratka, dovoli samo 2 simki ali simko in SD kartico.
Če kdo uporablja to me zanimajo izkušnje ali mogoče NOTE 9 to res ne dovoli ali sem jaz kaj pokvaril tisto napravico ali kaj za vraga je narobe?? Saj je res 128 GB dovolj prostora ampak če že imam SD kartico, zakaj ne bi bila noter....!
- Rast
- Prispevkov: 334
No sem še malo brskal okoli te moje težavice in sem na strani kjer sem kupil to zadevo za 2 simki in SD kartico (https://getpocket.com/a/read/2056476261) prebral da to TRENUTNO ni mogoče na samsung telefonih z android 8 in 9.
Malce čudno, meni je do včeraj ko sem opravil menjavo fonov lepo delovalo na NOTE 8 z androidom 8.
- Rast
- Prispevkov: 334
Mogoče na EU Note8 še ni prišel Samsung update, ki to onemogoča in da sporočilo o "tujku" v telefonu kot si napisal.
So pa ti adapterčki zgleda zelo slabe kvalitete, brati je bilo kar nekaj pritožb, da se notri nekaj polomi, ko adapterček odstranjuješ iz reže.
- s5en3besman
- Prispevkov: 204
Ja imaš prav, te možnosti dveh simk in SD kartice ni več na NOTE 9. Sem prebral na tujih forumih da se to dogaja mnogim, enako sporočilo. Mogoče bo pa kdo v prihodnosti le pogruntal kako to obiti...!
Drugače sem pa zelo zadovoljen z mojo pridobitvijo, posebej me navdušuje intelligent scan ki odklepa fon v kombinaciji prepoznavanja obraza in oči, pa tudi baterija ni slaba čeprav še mora narediti par cikov.
- Rast
- Prispevkov: 334
Tako ovitek je prišel, enkrat za spremembo pred telefonom, kupca za p20 pro tudi že imam.. Zdaj pa samo še čakam kakšno pametno ponudbo na bolhi
Sent from my CLT-L29 using Tapatalk
Google Pixel 2 XL
- linux
- Prispevkov: 318
- Pridružen: 23 sep 2012, 21:33
- Prejete zahvale: 19
- Naprava: iPhone 7 Plus
Kaj pa je pametna ponudba?
jst - AncientDroid
- Prispevkov: 2934
- Pridružen: 03 nov 2012, 14:03
- Prejete zahvale: 153
- Naprava: Samsung Galaxy S7 Edge
Po moje po njegovo 600 eur cca [FACE WITH TEARS OF JOY]
Sent from my SM-N960F using Tapatalk
- doctor78
- Prispevkov: 267
- Pridružen: 10 dec 2013, 12:55
- Prejete zahvale: 20
- Naprava: SM-950F
Takrat bo že note 10 zunaj.
jst - AncientDroid
- Prispevkov: 2934
Cena bo pomoje padla malo pod 700 eur pol pa dolgo nic. Linux, hitreje si zamenjal kot sem mislil da bos, glede na to kako si bil navdusen nad p20 pro
markic22 - Moderator
- Prispevkov: 1966
- Pridružen: 26 maj 2011, 10:42
- Kraj: Ljubljana/Novo mesto
- Prejete zahvale: 427
- Naprava: Galaxy Note 3 & Galaxy Note 4
Nekako tema ni preveč živahna. A nimate nič dobrega ali slabega za povedat? Dajte no malo pokomentirati... [FACE SAVOURING DELICIOUS FOOD]
Sam sem ga potestiral za en dan, super zadeva, glede na to da, je bil moj zadnji note 2. Tudi samsung preobleka se izbolsuje. Moram rect, da me je mikalo da bi ga vzel, ampak bom pocakal na Pixel3 pa se potem odlocim.
gabrca - AncientDroid
- Prispevkov: 501
- Pridružen: 15 avg 2012, 10:12
- Prejete zahvale: 24
- Naprava: iPhone 8Plus, Google Pixel
Jaz ga imam dva tedna in moram rect, da je to najboljsi telefon do sedaj. Do sedaj nimam pripomb. Skoda, ker nas imajo za drugo oz tretjerazredne potrosnike in ni na voljo pri nas 512/8GB verzija. Je pa se vedno prostora za izboljsavo. Recimo fast charging bi lahko bil hitrejsi, saj obstaja tehnologija, ki pa je Samsung zaradi fiaska z Note 7 ni zelel uporabiti. To je edina kritika, ki jo imam do sedaj saj me je moj 1+6 pri tem razvadil.
- doctor78
- Prispevkov: 267
- Naprava: SM-950F
Itak gre za best productivity phone in njegove prednosti prevagajo nad sem ali tja kakšno slabostjo.
Moja želja do Samsunga pa je, da ne bi ločeval regij in ponujenih barv
Že lani sem zvisel, ker bi želel imeti modrega in sem se moral zadovoljiti z dolgočasnim črnim, no je vsaj moder case padu, letos bi pa Metallic Copper izbral, če bi imel možnost izbire med vsemi barvami.
Blutooth pen je kar dobra zadeva in ima še kar placa za izboljšave, sam bi želel malo daljšo avtonomijo. Res, da se fila hitro, ampak vidim situacije, kjer bi bilo dobro, če bi zdržal urco do dve.
Z vsem ostalim pa zaenkrat zadovoljen, tudi sound je presenečenje glede na prejšnje serije.
- s5en3besman
- Prispevkov: 204
Vezano na temo dveh sim i micro sd hkrati, v note 8 mi je super delovalo(navodila s yutuba), na note 9 mi kaže da je tujek v reži. Očitmo so pr Samsungu nekaj naredili da ne laufa. Pa oba not sta duos verzija.
- rp
- Prispevkov: 26
- Pridružen: 15 sep 2016, 14:38
- Naprava: Note 1,2,3,4,5,8,9,10+,20ultra, S22ultra
Ja žal je res, o tem sem že pisal malo zgoraj, tudi meni je na NOTE 8 delovalo, sedaj pa ne, Samsung je to nekako programsko zablokiral, enako se pritožujejo tudi na tujih forumih. Upajmo da bo mogoče kdo v prihodnosti pokruntal kako to "odkleniti", z rootanjem pa se ne mislim zajebavati....
- Rast
- Prispevkov: 334
Kakor me sicer moj NOTE 9 v glavnem navdušuje me ob enem jezi vedno čudna diskriminatorska politika Samsunga do nekaterih regij, trgov....Kot recimo da pri nas ni na voljo močnejša verzija NOTE 9.
Ali recimo da razen v USA, Angliji, Koreji ni na voljo odlična aplikacija, pravzaprav pravi sistem aplikacij GOOD LOCK 2018 (https://www.xda-developers.com/samsung- ... roid-oreo/ ). Sicer se jo da instalirati z veliko muke in potem imaš vedno cirkus ob spremembah nastavitev znotraj aplikacije.
Škoda!
Škoda!
- Rast
- Prispevkov: 334
Zadnč sm vidu enga Indijca na YT, imajo že serijsko Call Recording, v EU je verjetno ta funkcija utopija zaradi vseh možnih zakonov o tašni ali drugačni zaščiti.
- s5en3besman
- Prispevkov: 204
