Huawei P20/P20 Pro
45 prispevkov
• Stran 1 od 2 • 1, 2
Huawei P20/P20 Pro
Huawei P20:
Body: dual-glass with metal frame, 7.65mm thick
Screen: 5.8" IPS LCD, 1080 x 2244 px resolution (429ppi);
Chipset: Kirin 970 chipset, octa-core processor (Cortex-A73 2.4GHz + A53 1.8GHz), Mali-G72 MP12 GPU
Memory: 4GB RAM, 64GB storage, microSD slot (hybrid, uses SIM2 slot)
OS: Android 8.1 Oreo with EMUI 8.1;
Camera: 12MP f/1.6 color + 20MP f/1.6 black & white, 4K video capture, 720p@960fps slow-mo, Leica branding
Camera features: F/1.6 lens, Hybrid Zoom (2x magnification), OIS + AIS, can change focus and lighting in photos after they are taken, Variable Aperture, Portrait Mode, can shoot long-exposure without a tripod
Selfie cam: 24MP, f/2.0 Leica lens, Portrait Mode with live bokeh effects; 2D Face Unlock
Battery: 3,400mAh; Super Charge
Security: Fingerprint reader (front), 0.4 seconds response time
Connectivity: Dual SIM, Wi-Fi a/b/g/n/ac, Bluetooth 4.2 + LE, NFC, USB Type-C
Misc: IR blaster, stereo speakers
Huawei P20 Pro:
Screen: 6.1" AMOLED, 1080 x 2244 px resolution (408ppi);
Memory: 6GB RAM, 128GB storage, microSD slot (hybrid, uses SIM2 slot)
Camera: 40MP f/1.8 color + 8MP f/2.4 color telephoto + 20MP f/1.6 black & white, 4K video capture, 720@960fps slow-mo, Leica branding
Camera features: 1/1.7" 40MP sensor, up to ISO 102,400, 3x optical zoom, 5x hybrid zoom, OIS + EIS, can change focus and lighting in photos after they are taken, Variable Aperture, Portrait Mode, can shoot long-exposure without a tripod
Battery: 4,000mAh; Super Charge
Re: Huawei P20/P20 Pro
Zgledata kar zanimiva telefona. Posebno PRO verzija, z veliko baterijo in baje odličnim fotoaparatom. DXOMARK tako zaključuje svoj test:
We are used to every new smartphone camera generation being slightly better than the previous one, but looking at the images and test results from the P20 Pro, it seems Huawei has skipped one or two generations. The results are simply that good. The P20 Pro’s triple camera setup is the biggest innovation we have seen in mobile imaging for quite some time and is a real game changer.
Being able to pick the best camera for a specific shooting situation and computationally merge the image data from all three sensors means that the new Huawei beats the competition in virtually every category, taking the number one spots in both our Photo and Video rankings. The P20 Pro is particularly good in low light, when zooming, and for bokeh simulation, blowing its direct rivals out of the water. If you are looking for the current best camera in a smartphone, look no further.
Osebno me sicer moti manko izhoda za slušalke.
Če bodo cene pri nas konkurenčne znata biti mamljiva alternativa samsungu.
Pismo hud k pes. Sam zasloni gredo pa res sam še gor. Sam res da velikost telefonov pa ista ostaja.
Poslano z mojega Redmi Note 4 z uporabo Tapatalk
- cresh
- Prispevkov: 640
- Pridružen: 12 jul 2010, 19:23
- Prejete zahvale: 36
- Naprava: Galaxy Nexus; LG Nexus 5; LG G3; Mate9
Isti kot Iphone X....
- Likalnik
- Prispevkov: 1631
- Pridružen: 10 jun 2010, 09:15
- Kraj: Lesce
- Prejete zahvale: 59
- Naprava: Nexus 6P
Imamo novo jabolko.
- Prispevkov: 8430
- Prejete zahvale: 1206
- Naprava: Pixel 4 XL PRODAM!
a jabolko ima fizični gumb??
res je enak
Poslano z mojega SM-G920F z uporabo Tapatalk
res je enak
Kdo kaj ve kako je s prednarocili? Danes naj bi se dalo ze narociti, pa noben ponudnik nima se na spletni strani.
- DennisDee
- Prispevkov: 1267
- Pridružen: 22 dec 2010, 11:44
- Prejete zahvale: 149
- Naprava: Samsung Galaxy S6
Prednaročila so možna od 9.4., obrni se na svojega izbranega operaterja, pa te bodo usmerili naprej. Je pa P20 na voljo od včeraj, 9.4., P20 Pro bo pa na voljo od 16.4. dalje.
P20 Pro dela brutalne fotografije! Predvsem nočni način je bomba, ker ne rabiš več stativa za perfektno sliko. Edino kar me moti je, da je malo debelejši od Mate 10 Pro, drugače pa skoraj identičnih dimenzij.
https://twitter.com/alexdobie/status/978758496014491648
Maxl - AncientDroid
- Prispevkov: 824
- Pridružen: 23 jan 2011, 16:59
- Prejete zahvale: 107
- Naprava: Mi 11 Ultra
Maxl, tvoj odgovor je dober in nepopoln hkrati. Kaj pa ce imam na voljo za izbiro katerega koli operaterja
Telemach so ze znane cene: 24,83-29EUR
a1 jih ne bo imel v ponudbi kot prednarocilo, bo pa nekaj prvim spletnim kupcem dal zraven kamero za 1EUR.
Telekom se nic ni znano.
- DennisDee
- Prispevkov: 1267
Telekom je imel v ponedeljek objavljeno ceno P20 - 20€x24mesecev za njihove najboljše pakete, potem pa so dali dol (danes v glavnem "ni na zalogi").
Tudi mene moti manjka audio konektorja, kako pa se kaj obnesejo Type-C -> headphone pretvorniki (upam da delujejo tukaj)?
@DennisDee: pravzaprav nihče od operaterjev nima pravega prednaročila, ampak gre bolj za rezervacijo aparata. Drugače ima tudi A1 rezervacijo - https://www.a1.si/huawei-p20-pro. Telekom bi pa načeloma tudi moral imeti rezervacije in za darilo kamero, ampak kot kaže ne bo imel.
@azisem: P20 je (spet) objavljen na TS (https://www.telekom.si/zasebni-uporabni ... a/mobiteli). Zraven v paketu dobiš type-C na aux prevornik in deluje brez težav. Jaz imam pretvornik kar konstantno priklopljen na slušalke, da ga ne izgubim
. Sicer pa dela brez težav s pretvorniki z Aliexpressa za evro ali dva.
Maxl - AncientDroid
- Prispevkov: 824
Izgleda jim komunikacija na fb in spletni strani ne stima skupaj
. Hvala Maxl
- DennisDee
- Prispevkov: 1267
Pozdravljeni.
Kako se kaj obnese tel? Razmišljam o pro modelu, baterija, zaslon, kamera? Hvala
Je možno nastaviti, da telefon zavibrira ob vzpostavitvi govorne povezave? Če se da? Kako?
Huawei mate 9 z uporabo Tapatalk
smajo
smajo - AncientDroid
- Prispevkov: 521
- Pridružen: 07 avg 2012, 08:25
- Kraj: hraše
- Prejete zahvale: 31
- Naprava: Lg g4 SMAJO
Mate 10 pro že privzeto zavibrira, ko se sogovornik oglasi na klic. Predvidevam da bi tudi P20 moral imeti to možnost, poglej v nastavitvah telefona.
bvader - AncientDroid
- Prispevkov: 1190
- Prejete zahvale: 147
Kupujem P20 pro in me zanima, če lahko kdo pove iz prve roke razliko med Galaxy S8/S9 - kamera, baterija, hitrost, uporabnost.....
Kamera naj bi bila vsaj tako dobra, v slikanju v temi se boljsa. Snemanje videov je katastrofalno ker nima OIS in se vse stresenje zelo pozna. Baterija je precej vecja in posledicno je avtonomija boljsa. Huawei ima svoj vmesni kot tudi Samsung. Lahko ti bo vsec ali pa ne. Custom romov ne pricakuj veliko ce sploh. Huawei ima svoje procesorne Kirin, ki so dovolj dobri. Moti me samo, da ne podpirajo wireless polnjenja.
Sent from my SM-G950F using Tapatalk
- doctor78
- Prispevkov: 267
- Pridružen: 10 dec 2013, 12:55
- Prejete zahvale: 20
- Naprava: SM-950F
Sem prebral in me res čudi, da nima OIS za snemanje videa....rad bi enkrat probal Huawei in me je malo strah, da ne bo slabše kot moj stari S8
Jaz sem hotu kupit mate 9 in mate 10pro, pa sem kar lepo se vedno na note 8.si nisem upal nakoncu narest spremembe, pa ceprav mi gre samsung ze mal na zivce;)
Ga nimam doma, zaradi dveh pomankljivosti, ampak ali ne uporablja OIS in EIS na 1080p. Pri snemanju videa seveda. Le pri 4K ga zajebava in pravijo da je neuporabno.
- Prispevkov: 3146
- Prejete zahvale: 302
Imel Mate 10 pro, se prepričeval en teden, da je to to, pa ni šlo. Pred tem sem imel Note 4,tri leta brez vsakih problemov. Vse kar mi je bilo všeč na 10 pro, je bila baterija, pa zvok, ekran je menjal barve kot kameleon, pisava, če je bila sive barve je bila komaj vidna in po kakšni uri me je začela boleti glava. Aparat je izklapljal aplikacije kot po tekočem traku, vsake toliko časa sem se moral na novo nekje prijaviti ali logirati. No tudi kamera ni bila slaba, slušalke so bile odlične. Kakorkoli, po tednu dni sem imel vsega dovolj in kupil nov Samsung s7 edge. Po prvem vklopu pa ooooh, končno spet doma. Huawei me ni prepričal, mislim da je moje druženje s to znamko končano. Verjamem, da to kakšnega drugega uporabnika ne bo odvrnilo od nakupa, pač vsakemu svoje
azagar2 napisal/-a:Jaz sem hotu kupit mate 9 in mate 10pro, pa sem kar lepo se vedno na note 8.si nisem upal nakoncu narest spremembe, pa ceprav mi gre samsung ze mal na zivce;)
Gligo napisal/-a:Imel Mate 10 pro, se prepričeval en teden, da je to to, pa ni šlo. Pred tem sem imel Note 4,tri leta brez vsakih problemov. Vse kar mi je bilo všeč na 10 pro, je bila baterija, pa zvok, ekran je menjal barve kot kameleon, pisava, če je bila sive barve je bila komaj vidna in po kakšni uri me je začela boleti glava. Aparat je izklapljal aplikacije kot po tekočem traku, vsake toliko časa sem se moral na novo nekje prijaviti ali logirati. No tudi kamera ni bila slaba, slušalke so bile odlične. Kakorkoli, po tednu dni sem imel vsega dovolj in kupil nov Samsung s7 edge. Po prvem vklopu pa ooooh, končno spet doma. Huawei me ni prepričal, mislim da je moje druženje s to znamko končano. Verjamem, da to kakšnega drugega uporabnika ne bo odvrnilo od nakupa, pač vsakemu svoje
No verjetno tudi spiš z samsungom, ker z huaweiem nisi mogel, zaradi slabosti pa to mislim.
Marsikaj sem že slišal ampak da te zaradi firme telefona boli glava pa še ne. Pol pa pravijo da so lastniki iphonov čudni.
45 prispevkov
