Samsung Galaxy S9 / S9+
Glede na to, da sta telefona praktično enaka in ker že pri S8 vidimo, da uspeva ena tema bo vsaj trenutno tudi tukaj. Kasneje se bo pa po potrebi odprla ločena tema.
S9+ razlike:
6.2 palčni zaslon
6GB RAMA
2x kamera
neodstranljiva 3500 mAh baterija
BODY
Dimensions 147.7 x 68.7 x 8.5 mm (5.81 x 2.70 x 0.33 in)
Weight 163 g (5.75 oz)
Build Front/back glass (Gorilla Glass 5), aluminum frame
SIM Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
- Samsung Pay (Visa, MasterCard certified)
- IP68 certified - dust/water proof over 1.5 meter and 30 minutes
DISPLAY
Type Super AMOLED capacitive touchscreen, 16M colors
Size 5.8 inches, 84.8 cm2 (~83.6% screen-to-body ratio)
Resolution 1440 x 2960 pixels, 18.5:9 ratio (~570 ppi density)
Multitouch Yes
Protection Corning Gorilla Glass 5
- HDR10 compliant
- 3D Touch (home button only)
- Always-on display
PLATFORM
OS Android 8.0 (Oreo)
Chipset Exynos 9810 Octa - EMEA
CPU Octa-core (4x2.7 GHz Mongoose M3 & 4x1.8 GHz Cortex-A55) - EMEA
GPU Mali-G72 MP18 - EMEA
MEMORY
Card slot microSD, up to 400 GB (uses SIM 2 slot) - dual SIM model only
Internal 64/128/256 GB, 4 GB RAM
CAMERA
Primary 12 MP (f/1.5-2.4, 26mm, 1/2.5", 1.4 µm, Dual Pixel PDAF), phase detection autofocus, OIS, LED flash, check quality
Features Geo-tagging, simultaneous 4K video and 9MP image recording, touch focus, face/smile detection, Auto HDR, panorama
Video 2160p@60fps, 1080p@240fps, 720p@960fps, HDR, dual-video rec., check quality
Secondary 8 MP (f/1.7, 25mm, 1/3.6", 1.22 µm), autofocus, 1440p@30fps, dual video call, Auto HDR
SOUND
Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes, with stereo speakers
3.5mm jack Yes
- 32-bit/384kHz audio
- Active noise cancellation with dedicated mic
COMMS
WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth 5.0, A2DP, LE, aptX
GPS Yes, with A-GPS, GLONASS, BDS, GALILEO
NFC Yes
USB 3.1, Type-C 1.0 reversible connector
FEATURES
Sensors Iris scanner, fingerprint (rear-mounted), accelerometer, gyro, proximity, compass, barometer, heart rate, SpO2
Messaging SMS(threaded view), MMS, Email, Push Mail, IM
Browser HTML5
- Samsung DeX (desktop experience support)
- Fast battery charging (Quick Charge 2.0)
- Qi/PMA wireless charging (market dependent)
- ANT+ support
- Bixby natural language commands and dictation
- MP4/DivX/XviD/H.265 player
- MP3/WAV/eAAC+/FLAC player
- Photo/video editor
- Document editor
BATTERY
Non-removable Li-Ion 3000 mAh battery (11.55 Wh)
- Prispevkov: 12358
Re: Samsung Galaxy S9 / S9+
Se odločam za S9+, ker imam še note 4. V predprodaji je kar ugodnejši, pa bo zato morala odločitev pasti še ta teden.
Zanimivo, da se nihče ne oglasi od tistih, ki so ga nabavili v prvi predprodaji in že dobili...
- virtuoz
- Prispevkov: 35
- Pridružen: 15 maj 2011, 12:23
Dobil sem ga v petek. Trenutno se še spoznavama, ker je prehod iz S6 na S9+ kr velik (za mene). Drugače pa me bo prišel 600€ (24*25,83 - 20€ ker sem naročil preko spleta) poslal pa bom še na RAM moj star telefon, da vidim koliko bi mi ponudili. Vendar ta stvar ni zavezujoča in ne rabim sprejet odkupne cene in dobim telefon nazaj. Ne zgubim pa teh 100€ popusta. Če bi naročil v normalno (ne v prednaročilu) bi bil obrok 30€.
Kar oa se samega delovanja tiče pa v primerjavi s S6 kr velik preskok. Imam pa Spigenov Neo Hybrid case in Panzeglasovo steklo, tako da je tudi izdatno zaščiten.
Kateri ponudnik pa ima tako ugodno? Telekom kjer sem jaz, ima ceno 720€ v prednaročilu, prav tako za zamenjavo starega.
- virtuoz
- Prispevkov: 35
Jaz sem vzel pri A1 paket Svobodni M (stari paket, za katerega pa velja cena od Svobodni 60. Ostal sem na starem paketu, ker imam še eno leto polovičko).
Tudi jaz imam S9+ od prejšnjega petka, pred tem sem imel OP 5T (8GB/128GB verzijo).
V menjavo pa sem šel skoraj izključno zaradi kamere, ki je na OP 5T dokajšnje razočaranje (zdi se mi, da je še OP3 delal lepše slike od OP 5T).
Če koga zanima kaj konkretnega, npr .primerjava med telefonoma ali kaj drugega o S9+, sem na razpolago
- toby
- Prispevkov: 179
- Kraj: Koper
- Prejete zahvale: 22
5T res nima dobre kamere. Veliko doplačila za S9, je vredno? Baterija, hitrost?
- eminemko
- Prispevkov: 63
- Pridružen: 08 jun 2011, 08:30
@eminemko
baterija je na 5T dosti boljša..
z istimi navadami uporabe in istimi aplikacijami sem na 5T imel cca 8hrs SOT, na S9+ prilezem nekje na 5-5,5 ur. Res pa je, da imam na S9+ vklopljen AOD od 6h zjutraj pa do polnoči
Na 5T sem si komot privoščil polnit baterijo vsaka 2 dni, galaxy-ja raje napolnim vsak dan zvečer, da sem naslednji dan miren
Oba sta hitra, nekako subjektivna ocena oz občutek pa je, da 5T vseeno dela bolj gladko
- toby
- Prispevkov: 179
- Kraj: Koper
aja, glede tega, če je vredno menjati ali ne
Odvisno od prioritet, ampak, ker se mene tiče, če bi le bila kamera na 5T boljša, ga ne bi menjal za samsunga
- toby
- Prispevkov: 179
- Kraj: Koper
No S9+ je doma... pa da vidimo kako in kaj.
- King1
- Prispevkov: 132
- Pridružen: 07 apr 2013, 09:08
- Prejete zahvale: 18
- Naprava: S22 Ultra nažalost
Tudi moj je že doma...
Me pa zanima, zakaj ko podrsam po preslednici za slo tipkovnico napiše da je slo, ampak šumnikov pa ni?
- virtuoz
- Prispevkov: 35
Pritisni in drži..npr s za š
- toby
- Prispevkov: 179
- Kraj: Koper
To poznam, samo na Note 4 je bila prava slo tipkovnica s šumniki.
- virtuoz
- Prispevkov: 35
Ej, kje se ga splača najbolj kupiti? pri telemachu je za 25€ in dober paket... pri ostalih nisem našel ceneje ali pač?
vzameš pakete ki ti ustrezajo pa vidiš po kaki ceni je in zračunaš.
note8 je bil pri telemachu v paketu še več (15 eur) za 36 eur (povsod drugje ceneje), ko pa si črto potegnil naročnina + telefon pa si videl da je telemach krepko ceneje kot drugje.
imaš tam v temi izračune ki sem jih delal in si lahko primerjaš za s9
- Prispevkov: 12358
Pri 8+ nisem imel take porabe baterije zaradi Always on display,tu pa je kar enormna!Kako je pa pri vas?!
SM-G965F
SM-G965F
mankomander - AdultDroid
- Prispevkov: 205
- Pridružen: 08 maj 2011, 11:11
saj se vidi da si na bateriji 2 dni, zaslon je bil pa prižgan 1 uro.
menda ja nisi mislil da če boš telefon imel 2 dni na mizi da bo še kar 100% ali pa najmanj 99% ?
- Prispevkov: 12358
To je dokaz, da ima telefon za izkazovanje. Važno, da piše S9.
- Prispevkov: 8430
- Prejete zahvale: 1206
- Naprava: Pixel 4 XL PRODAM!
No res ste domiselni z odgovori!
SM-G965F
SM-G965F
- Prispevkov: 205
kaj ti pa naj druga odgovorim? 2 dni od zadnjega poljenja. od tega si samo 1 uro telefon uporabljal. ker pa telefona nisi imel druga kot na mizi pa je itak največji in edini porabnik ravno always on display
to je to.....
to je to.....
- Prispevkov: 12358
greenmen napisal/-a:To je dokaz, da ima telefon za izkazovanje. Važno, da piše S9.
haha...
gabrca - AncientDroid
- Prispevkov: 501
- Pridružen: 15 avg 2012, 10:12
- Prejete zahvale: 24
- Naprava: iPhone 8Plus, Google Pixel
Zanimivo, kako nekateri hitro "navalite" na nove serije telefonov.
Jaz ga nimam, sem z Note4 izredno zadovoljen (SPen je nepogrešljiv dodatek).
Sploh pa me ne pritegnejo telefoni, katerim se ne da odstranit baterije (mislim normalno odstranitev).
Vsem lastnikom pa užitek ob uporabi.
YAMAHA - WisdomDroid
- Prispevkov: 421
- Pridružen: 28 apr 2011, 08:51
- Prejete zahvale: 15
- Naprava: Samsung Galaxy NOTE 8
Jelly?
de marco - AncientDroid
- Prispevkov: 2068
- Prejete zahvale: 160
