LG V30
33 prispevkov
• Stran 1 od 2 • 1, 2
LG V30
LG V30
zadnja informacija: v SLO dobavljiv decembra 2017
SPECIFIKACIJE
Body
Dimensions 151.7 x 75.4 x 7.4 mm
Weight 158 g
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
- MIL-STD-810G compliant
- IP68 certified - dust/water proof over 1.5 meter and 30 minutes
Display
Type P-OLED capacitive touchscreen, 16M colors
Size 6.0 inches (~81.2% screen-to-body ratio)
Resolution 1440 x 2880 pixels (~537 ppi pixel density)
Multitouch Yes
Protection Corning Gorilla Glass 5
- Dolby Vision/HDR10 compliant
- Always-on display
- LG UX 6.0+
Platform
OS Android 7.1.2 (Nougat)
Chipset Qualcomm MSM8998 Snapdragon 835
CPU Octa-core (4x2.45 GHz Kryo & 4x1.9 GHz Kryo)
GPU Adreno 540
Memory
Card slot microSD, up to 256 GB (dedicated slot)
Internal 64 GB, 4 GB RAM
128 GB, 4 GB RAM - V30+
Camera
Primary Dual 16 MP (f/1.6, OIS, 3-axis, laser & phase detection autofocus) + 13 MP (f/1.9, no AF), LED flash, check quality
Features 1.0 µm pixel size, geo-tagging, touch focus, face detection, HDR, panorama
Video 2160p@30fps, 1080p@30fps, 720p@120fps, 24-bit/192kHz stereo sound rec., HDR video, check quality
Secondary 5 MP, f/2.2, 1/5" sensor size, 1.12 µm pixel size
SPECIFIKACIJE
Body
Weight 158 g
Display
Multitouch Yes
- Always-on display
- LG UX 6.0+
Platform
GPU Adreno 540
Memory
Camera
- Prispevkov: 3099
- Prejete zahvale: 296
Re: LG V30
+1
de marco - AncientDroid
- Prispevkov: 2066
- Prejete zahvale: 159
Re: LG V30
Jaz bom videl kakšno bo stanje, pa se po 15 letih spet malo vežem.
mi je po dolgem dolgem času spet LG dober.
- Prispevkov: 3099
Re: LG V30
imam informacijo,da bo V30 v slo cenejši kot v Eu pa za prednaročilo bo nekaj koristnega zdraven.
- raay
- Prispevkov: 220
- Pridružen: 25 dec 2010, 11:18
- Kraj: Auckland
- Naprava: Galaxy Note 9,Mate 20 Pro,Oneplus McLar
Re: LG V30
super novica. zaradi takšnih se splača odpreti temo.
Vprašanje je le ČAS
Vprašanje je le ČAS
- Prispevkov: 3099
- raay
- Prispevkov: 220
- Kraj: Auckland
Re: LG V30
novembra naj bi se pobirala prednaročila v prodajo naj bi prišel v začetku decembra v dveh barvah in sicer v modri in srebrni
- raay
- Prispevkov: 220
- Kraj: Auckland
Re: LG V30
Mene je skoraj da ta Wide angle kamera cisto prepricala. Se vedno razmisljam o nakupu 4k kamere ali pa bom imel posnetke kar s telefonom (v30). Vsekakor ima potencial pred drugimi, ker me te 2x zoom, ipd niti ne zanimajo. Sploh pa ta posnetek z vs Red kamero je ubijalski. Vem, veliko je narejenega v softwareu, kar tudi pove v primerjavi.
- DennisDee
- Prispevkov: 1266
- Pridružen: 22 dec 2010, 11:44
- Prejete zahvale: 148
- Naprava: Samsung Galaxy S6
Re: LG V30
https://www.theverge.com/2017/10/16/164 ... iew-design tale okoli ekrana je hladen tuš...
Re: LG V30
zanimivo, lahko da je imel ravno nek defekten model?
Eni grajajo zaslon, drugi hvalijo...
http://www.techradar.com/reviews/lg-v30
https://www.digitaltrends.com/cell-phon ... 30-review/
https://www.androidcentral.com/lg-v30-review
https://www.gsmarena.com/lg_v30-review-1657p9.php
Dokler ne vidimo telefona v živo, je tole vse tak tak.
Gorgeous OLED display
OLED screen
Display has contrast issues at darker brightness levels.
Re: LG V30
cena bo 800eur,na prodaj bo v začetku decembra v dveh barvah,srebrni in modri predvidoma bojo pa prednaročila nekje v sredini novembra,
Drugače ima pa LG od ponedeljka naprej nagradno igro inn,če bo imel kdo dovolj znanja in časa ga lahko dobi brezplačno.
vse informacije so na fb in instagram strani od lg mobile slovenija
- raay
- Prispevkov: 220
- Kraj: Auckland
Re: LG V30
Jaz imam testnega pa mi je bomba vse dela zelo hitro v primerjavi z samsungom S8+ ali note 8,čakam samo,da dobim retail verzijo,ker tega testnega ne morem posodobit in se je zataknil nekje v avgustu pa tudi kamera je na testnem slabša kot na retail 2.0 proti 1.6.
Najbolj mi je pa všeč en kup nastavitev pri kameri predvsem zvok je odličen pa tudi slušalke B&O so dosti boljše kot AKG od Samsunga
Baterija pa dela presenetljivo dobro navkljub temu da ima samo 3300mah
- raay
- Prispevkov: 220
- Kraj: Auckland
Re: LG V30
Ali lahko kdo od lastnikov telefona pogleda če se da instalirat Google Phone aplikacijo
https://play.google.com/store/apps/details?id=com.google.android.dialer
- blackbird
- Prispevkov: 185
- Pridružen: 21 apr 2011, 18:13
- Prejete zahvale: 20
- Naprava: Pixel 2 XL
Re: LG V30
Ni na nivoju zadnjih samsungov, ni pa tudi tako zanič kot nekateri pravijo. Pod kotom hitreje postane modrikast (na mojem s8 je sicer bilo sicer skoraj enako) in pa na belih ozadjih je malenkost šuma.
Meni je dovolj dober, pa sem ravno zaradi zaslona odlašal z nakupom
Govorim sicer za Pixla 2XL, ki pa ima itak enak zaslon kot v30.
Sent from my Pixel 2 XL
mm46 - Moderator
- Prispevkov: 1426
- Pridružen: 13 maj 2010, 09:20
- Kraj: Izola
- Prejete zahvale: 347
- Naprava: iPhone Xs, Google Pixel 2 XL
Re: LG V30
Ekran je čisto spodoben,tudi telefon kot tak je super paket...Razen manjko led lucke za notificatiine?10C so sparali pri LG-ju
Poslano z mojega LG-H930 z uporabo Tapatalk
Gi3M0 - Administrator
- Prispevkov: 5450
- Kraj: Cukeršpic
- Prejete zahvale: 805
- Naprava: G955F & SM-R760
Re: LG V30
Čudno da ne dajo tega gor. Daj gor aplikacijo led blinker, pa lahko nastaviš da ti javlja.
33 prispevkov
Po forumu brska: 0 registriranih uporabnikov in 6 gostov
