http://www.gsmarena.com/samsung_galaxy_note8-8505.php
Specifikacije:
Mere: 162.5 x 74.8 x 8.6 mm
Teža: 195 g
Telo: Polished aluminum frame, Gorilla Glass 5 front and back; IP68 certified for water and dust resistance.
Barve: Midnight Black, Orchid Grey, Deepsea Blue, Maple Gold color schemes.
Zaslon: 6.3" Super AMOLED 'Infinity Display', 2,960x1440px resolution, 18.5:9 (2.06:1) aspect ratio, 522ppi; HDR 10 compliant (no Dolby Vision).
Zadnja kamera: Primary 12MP, Type 1/2.55" sensor, f/1.7 aperture, 26mm equiv. focal length; Secondary 12MP, Type 1/3.4" sensor, f/2.4 aperture, 52mm equiv. focal length; dual pixel phase detection autofocus and OIS on both; 2x zoom. 2160p/30fps video recording.
Prednja-Selfi kamera: 8MP, f/1.7 aperture, autofocus; 1440p/30fps video recording.
OS/Software: Android 7.1.1 Nougat; Samsung Grace UX; Bixby virtual assistant; Smart Connect, Smart Connect Home
Procesor: Qualcomm Snapdragon 835: octa-core CPU (4x2.35GHz Kryo 280 & 4x1.9GHz Kryo 280), Adreno 540 GPU. Exynos 8895: octa-core CPU (4x2nd-gen Mongoose 2.3GHz + 4xCortex-A53 1.7GHz), Mali-G71 GPU.
Spomin: 6GB of RAM; 64GB of storage; microSD slot for cards up to 256GB, UFS cards support.
Baterija: 3,300mAh Li-Po (sealed); Adaptive Fast Charging (same as S7/S8); QuickCharge 2.0 support; WPC (Qi)&PMA wireless charging.
Povezljivost: Single-SIM, Dual-SIM available in certain markets; LTE-A, 4-Band/5-Band carrier aggregation, Cat.16/13 (1Gbps/150Mbps); USB Type-C (v3.1); Wi-Fi a/b/g/n/ac MU-MIMO; GPS, Beidou, Galileo; NFC; Bluetooth 5.0.
Misc: S-Pen stylus with 4096 pressure levels; fingerprint/iris/face recognition; single speaker on the bottom; 3.5mm jack; bundled AKG headphones.
big bang že ima prednaročilo
https://www.bigbang.si/samsung-note-8
pri drugih zaenkrat še nisem opazil
- Uporabniku darkside so se za prispevek zahvalili:
- Nietzschean
- Prispevkov: 12357
Huh, še ene 70€ dol na tole ceno, pa je to to...
Nietzschean - AncientDroid
- Prispevkov: 1219
- Pridružen: 08 avg 2011, 19:06
- Prejete zahvale: 210
- Naprava: SGN8 & SG TAB S6
Ne vem no
Glede na prejšnje izkušnje, vas še vedno ni izučilo. Eni ste še vedno pripravljeni dat 1000€ za mačka v žaklju. No pa tudi, če ne bi bilo tistega fijaska s Note7, ni šanse, da bi dal tolko za telefon.
Jaz razmišljam da bi ga vzel, pa se vseeno strinjam s teboj. Nič pretirano pametnega ni v takem nakupu. Ampak, telefon imam namesto prenosnika in čeprav to ni vedno najbolj praktično, mi je bolj simpatično, kot prenašanje tablice ali prenosnika.
- Prispevkov: 1219
Saj s postajo dex pa se se bolj pribliza kot da je prenosnik. Ravno zato me mogoce vlece ceprav je res malo prevec.
Je kdo zasledil ce ima ir da ga lahko uporabljas kot daljinec? Na note3 sem uporabljal, na s7 pa malo pogresam
- Prispevkov: 12357
Jp, DEX bo zanimiv za uporabnike, ki imamo telefon namesto prenosnika.
In ne, žal nima IR blasterja.
- Prispevkov: 1219
Dex lahko sicer uporabljaš tudi s 300eur cenejšim s8+ (gledam cene na amazon.de)
Nima IR.
Sent from my Pixel using Tapatalk
Nima IR.
mm46 - Moderator
- Prispevkov: 1426
- Pridružen: 13 maj 2010, 09:20
- Kraj: Izola
- Prejete zahvale: 347
- Naprava: iPhone Xs, Google Pixel 2 XL
Glede ir samo namig, imaš tudi ip2ir pretvornike za nekaj evrov, torej prek wifi pošlješ komando ir oddajniku, ki to naprej pošlje ciljni napravi.
Poslano z mojega SM-G950F z uporabo Tapatalk
lukabike - AncientDroid
- Prispevkov: 882
- Pridružen: 23 feb 2011, 12:56
- Prejete zahvale: 74
- Naprava: Samsung Galaxy S4
Tudi mene precej mika, da bi ga prednaročil. Ampak je razlika med S8+ in N8 premajhna. Vleče me predvsem s pen, malo manj pa dvojna kamera. Močno sem upal, da bo N8 dobil stereo zvočnike ala HTC 10, Mate 9 in iPhone 7, ampak žal tega niso dodali. Tako, da sem zdaj v resni dilemi, še posebaj, ker mi bo tistih 200 mA pri bateriji znalo kak dan manjkati. Bomo videli...
Sent from my SM-G955F using Tapatalk
Mene tudi note8 mika zaradi s pena
- Prispevkov: 12357
Jah, pri nas še mobilno omrežje Telekom danes ne dela, tako da kake hitre ponudbe novih telefonov tako ali tako nisem pričakoval
- Prispevkov: 1219
pri telekomu bo kmalu. telemach ima pa v paketu še več za 35,91 eur. a1 (bivši simobil) pa sprejema rezervacije. cen za pakete še ni.
za telemach sem dobil ceno na zs ko sem videl objavo na fb. čeprav na strani nisem opazil.
moram dobiti info koliko stane v paketu več ker potem bi vzel telefon na mamo ker jaz odplačujem še iphona in glede na to da je obrok 32 eur pa še nekaj potem tudi ne bo verjetno preveč moreče za note8.
- Prispevkov: 12357
Vidim, da bodo pri nas N8 dual sim. To bi me pa znalo resno zamikati...
Ze v s7 lahko spravis 2x sim pa sd kartico hehe
- Prispevkov: 12357
Ja ampak le, ce imas duos verzijo. Moj s8 plus mislim, da ne spozna dveh kartic. Moraš imeti duos verzijo...
Telekom za poslovne uporabnike ponuja možnost prijave na info glede Note8. http://www.telekom.si/podjetniki/mobite ... laxy-note8
Na zalogi 15.9.2017
Na zalogi 15.9.2017
- Prispevkov: 1219
samo za info. meni je všeč. če je pa na s8 enako pa ne vem.
notification bar lahko odprete z fingerprint senzorjem https://youtu.be/gEyJ4s39Hfs?t=57s
moram pa videti s8+ kako mi sede v roko in žep. če štima vse potem gremo kar po note8. brez odplašanja. prednaročilo 1000 eur, v naročnini 860 eur. seveda ni kaj razmišljati.
aja, enostavno pogrešam s pen. sicer nisem veliko uporabljal ampak sedaj ko ga nimam vidim kako uporabna zadevca mi je bila
- Prispevkov: 12357
Jst ga bom verjetno tudi zaradi s pena vzel. Itak mi je note 3 do sedaj lepo služil, le baterija mu počasi peša, pa je še prva. Upam da bo več sreče kot z note 7, ko ga je bilo treba vrnit [SMILING FACE WITH SMILING EYES]. S pen mi pa tudi lepo služi, se ga navadiš...
Poslano z mojega SM-N9005 z uporabo Tapatalk
jaz pa mislim da bo tale telefon imel več sreče. zakaj? samsung si je ustvaril nek slabši sloves s note7 in napake ne bodo ponovili saj so videli kakšno finančno luknjo jim je pustil in so želeli tokrat narediti kot je treba
- Prispevkov: 12357
