Samsung Galaxy S8 / S8+
Št. objave:#1  OdgovorNapisal/-a LPKA » 31 mar 2017, 08:03
Samsung je predstavil nova "flagship-a".
Review:
Specifikacije:
Coming:April 21st
Body
Dimensions 148.9 x 68.1 x 8 mm / 159.5 x 73.4 x 8.1 mm
Weight 155 g /173 g
Build Corning Gorilla Glass 5 back panel
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
- Samsung Pay (Visa, MasterCard certified)
- IP68 certified - dust/water proof over 1.5 meter and 30 minutes
Display
Type Super AMOLED capacitive touchscreen, 16M colors
Size 5.8 inches (~83.6% screen-to-body ratio) / 6.2 inches (~84.0% screen-to-body ratio)
Resolution 1440 x 2960 pixels (~570 ppi pixel density) / 1440 x 2960 pixels (~570 ppi pixel density)
Multitouch Yes
Protection Corning Gorilla Glass 5
- 3D Touch (home button only)
- Always-on display
- TouchWiz UI
Platform
OS Android OS, v7.0
Chipset Qualcomm MSM8998 Snapdragon 835 - US model
Exynos 8895 Octa - EMEA
CPU Octa-core (4x2.35 GHz Kryo & 4x1.9 GHz Kryo) - US model
Octa-core (4x2.3 GHz & 4x1.7 GHz) - EMEA
GPU Adreno 540 - US model
Memory
Card slot microSD, up to 256 GB (dedicated slot) - single-SIM model
microSD, up to 256 GB (uses SIM 2 slot) - dual-SIM model
Internal 64 GB, 4 GB RAM
Camera
Primary 12 MP, f/1.7, 26mm, phase detection autofocus, OIS, LED flash
Features 1/2.5" sensor size, 1.4 µm pixel size, geo-tagging, simultaneous 4K video and 9MP image recording, touch focus, face/smile detection, Auto HDR, panorama
Video 2160p@30fps, 1080p@60fps, HDR, dual-video rec.
Secondary 8 MP, f/1.7, autofocus, 1440p@30fps, dual video call, Auto HDR
Sound
Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
- 24-bit/192kHz audio
- Active noise cancellation with dedicated mic
Comms
WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth v5.0, A2DP, LE, aptX
GPS Yes, with A-GPS, GLONASS, BDS, GALILEO
NFC Yes
Radio No
USB v3.1, Type-C 1.0 reversible connector
Features
Sensors Iris scanner, fingerprint (rear-mounted), accelerometer, gyro, proximity, compass, barometer, heart rate, SpO2
Messaging SMS(threaded view), MMS, Email, Push Mail, IM
Browser HTML5
Java No
- Samsung DeX (desktop experience support)
- Fast battery charging
- Qi/PMA wireless charging (market dependent)
- ANT+ support
- S-Voice natural language commands and dictation
- MP4/DivX/XviD/H.265 player
- MP3/WAV/eAAC+/FLAC player
- Photo/video editor
- Document editor
Battery
Non-removable Li-Ion 3000 mAh battery / Non-removable Li-Ion 3500 mAh battery
Misc
Colors Midnight Black, Orchid Gray, Arctic Silver, Coral Blue, Maple Gold
SAR EU 0.32 W/kg (head) 1.27 W/kg (body)
Prispevkov: 3127
Prejete zahvale: 299
Naprava: Z-Fold-2/Fenix6Titanium
Re: Samsung Galaxy S8 / S8+
Št. objave:#2  OdgovorNapisal/-a LPKA » 31 mar 2017, 11:10
na popravil, bo OK?
Ker se je izkazalo, da do dobavljivosti telefona, je brezveze imeti dve enaki temi, ker imamo potem dvakrat toliko vprašanj in sta telefona skoraj enaka.
Tako da vsa vprašanja ideje ter odgovore prosim v to temo, da bo bolj razvidna.
Ko pa pride v roke uporabnika S8+ ter z njim prvi problem, pa lahko z veseljem odpremo še eno temo.
Prispevkov: 3127
Št. objave:#3  OdgovorNapisal/-a greenmen » 31 mar 2017, 11:48
Razočaran, nič od napovedi dimenzij, da bo nižji, širši od S7. S8 bo višji in tanjši od S7. Eh..
Prispevkov: 8430
Prejete zahvale: 1206
Naprava: Pixel 4 XL PRODAM!
Št. objave:#4  OdgovorNapisal/-a Picaso » 31 mar 2017, 14:13
LPKA napisal/-a:na popravil, bo OK?
Ja tako kot je bilo s S6, S6 edge in S6 edge plus :-\
Spet isto. Vse bo v eni temi in nobeden ne bo vedel o čem se govori.
Potem je prepozno. Itak pol naj pa jaz prestavljam.
Prispevkov: 6703
Prejete zahvale: 861
Št. objave:#5  OdgovorNapisal/-a Picaso » 31 mar 2017, 14:16
greenmen napisal/-a:Razočaran, nič od napovedi dimenzij, da bo nižji, širši od S7. S8 bo višji in tanjši od S7. Eh..
Se strinjam. Saj ne rečem, da pod pokrovom ne bo zverina samo po videzu mi pa tej visoki in ozki telefoni(tudi LG G6) sploh niso všeč.
Prispevkov: 6703
Št. objave:#6  OdgovorNapisal/-a greenmen » 31 mar 2017, 14:34
Glede dimenzij je bil najbolj posrečen S4.
Prispevkov: 8430
Št. objave:#7  OdgovorNapisal/-a frenk27 » 31 mar 2017, 14:37
Za mene osebno je pa to najlepši in naj atraktivnejši telefon trenutno na trgu, tako po videzu in tudi po strojni konfiguraciji. Verjamem, da bo s prodajnostjo Samsung podiral vse rekorde. Pomojem bo to ened najbolj zaželjenih telefonov v letošnjem letu :) Tudi sam razmišljam da bi si ga nabavil, moram rečt da me je čist prevzel, pa čeprav sem si obljubil, da mora moj Note 4 pri meni zdržati rekordnih 4 leta, ker trenutno moram žal telefone premakniti na stranski tir, ker je trenutno pri meni mnogo več stroškovno pomembnejših stvari v planu. Ambak, kot sem že omenil, težko se mu bom uprl..... :)
frenk27
Prispevkov: 523
Pridružen: 16 nov 2010, 13:25
Kraj: 1310 Ribnica
Naprava: Samsung Galaxy S10+
Št. objave:#8  OdgovorNapisal/-a DennisDee » 31 mar 2017, 15:47
Ce bi to rekel nekdo, ki nima Samsunga, bi ga se resno vzel :P
Salo na stran, telefon je atraktiven, ni pa velik napredek napram s7/s7e. Videlo se bo v sami uporabi, ko si ga bodo ljudje dejansko lastili. Ampak ze zdaj prvi handson niso ravno nekaj wow.
Glede na to, kar sem prebral in gledal na yt handson:
- Bixby je preoblecen GA, nic posebnega, samo dodatno vrednost da telefonu na policah in proizvodnji
- Glede na super duper extra ekran, je baterija dokaj mala. Bomo videli kalo se obnese v uporabi
- Kamera, ce se ne motim je identicna s7?
+ 10nm procesor
+ infinity display
Prispevkov: 1267
Prejete zahvale: 149
Št. objave:#9  OdgovorNapisal/-a notefreak » 31 mar 2017, 19:50
Jaz tudi nisem najbolj navdušen. Že od Note5 furajo 4GB rama, baterija izjemno švoh, bizarne dimenzije (s8 premali, s8+ prevelik), če bi me pa že uspeli pritegnit, bi me pa mogoče dizajn - če bi bila na voljo modro barva pri nas in to po celotnem telefonu, ne samo na zadnjem delu.
notefreak
Prispevkov: 221
Pridružen: 05 sep 2016, 11:59
Št. objave:#10  OdgovorNapisal/-a Picaso » 31 mar 2017, 19:53
DennisDee napisal/-a:- Kamera, ce se ne motim je identicna s7?
Zadnja po specifikacijah ja.
Prednja selfi naj bi bila malo boljša.
napram
5 MP, 1/4.1" sensor size, 1.34 µm pixel size, f/1.7, 22mm, dual video call, Auto HDR
Prispevkov: 6703
Št. objave:#11  OdgovorNapisal/-a frenk27 » 31 mar 2017, 22:01
Vseskup mal pozabljate, da je blo rečeno, da naj bi bil novi procesor veliko bolj energijsko varčnejši napram S7 ( ok saj vem, na papirju, nekaj pa tut mora bit na tem ), tako da če mene uprašate, so baterije 3000 mah, ali 3500 mah več kot dovolj, in za moje pojme ni razloga, da avtonomija nebi bila dovolj dobra. Kar se pa tiče rama je pa tako, da je v praksi 4 gb rama več kot dovolj, sploh če je softwer dobro spisan, da zna dobro razpolagati z pomnilnikom. Se mi zdi, da so pri Samsungu končno doumeli, da specifikacije niso vse, ambak dobro spisan softwer, in to tako pri večopravilnosti programov, kot tudi pri fotiču, ki je zadolžen za procesiranje slike.... :)
frenk27
Prispevkov: 523
Kraj: 1310 Ribnica
Št. objave:#12  OdgovorNapisal/-a gabrca » 31 mar 2017, 22:19
Kamera je popolno ista, razen sprednje, je pa softwersko izboljsana, tako da bo malenkost razlike vrjetno.
gabrca
Prispevkov: 501
Pridružen: 15 avg 2012, 10:12
Prejete zahvale: 24
Naprava: iPhone 8Plus, Google Pixel
Št. objave:#13  OdgovorNapisal/-a kation_id » 01 apr 2017, 10:52
http://m.racunalniske-novice.com/index. ... onije.html
:o Ce je kaj na tem, glede na doticni vir in seveda datum >:D ... ???
kation_id
Prispevkov: 211
Pridružen: 22 jun 2016, 03:29
Kraj: Svetovljan
Prejete zahvale: 27
Št. objave:#14  OdgovorNapisal/-a andrej992 » 01 apr 2017, 11:52
Dobro da je danes prvi April ;D Meni je všečn in ga bom nabavil skoraj 100% poleti, ker trenutni telefon mi živce žre :D
andrej992
Prispevkov: 24
Pridružen: 30 okt 2016, 12:16
Št. objave:#15  OdgovorNapisal/-a SG2 » 01 apr 2017, 13:46
Definitivno bom vzeu s8+ ☺ sm zvest samsungu pa ceprov so mel probleme z notom 7.. z s7 pa ne ;) Prehodni so bli S2 S3 in trenutno S4 :P
Aja pa upam da tole drzi( tud ce bo 35mins bo ok)
https://www.gizmochina.com/2017/03/28/s ... -s-charge/
SG2
Prispevkov: 329
Pridružen: 19 maj 2011, 16:51
Naprava: Samsung galaxy S10+
Št. objave:#16  OdgovorNapisal/-a kation_id » 02 apr 2017, 00:07
kation_id
Prispevkov: 211
Kraj: Svetovljan
Prejete zahvale: 27
Št. objave:#17  OdgovorNapisal/-a Troba » 04 apr 2017, 11:18
Troba
Prispevkov: 163
Pridružen: 01 jul 2011, 22:24
Št. objave:#18  OdgovorNapisal/-a cult » 04 apr 2017, 12:14
cult
Prispevkov: 2781
Pridružen: 26 mar 2010, 09:31
Kraj: Domžale
Prejete zahvale: 369
Naprava: Samsung A50
Št. objave:#19  OdgovorNapisal/-a darkside » 04 apr 2017, 12:52
cena v naročnini je pa tako podobna kot je bil s7 in s7 edge v prednaročilu.
Prispevkov: 12358
Prejete zahvale: 1656
Naprava: Samsung Galaxy S22 Ultra
Št. objave:#20  OdgovorNapisal/-a SG2 » 04 apr 2017, 17:55
so že takoj zjutri klical :D je naročen s8+ ;D
http://www.phonearena.com/news/Samsung- ... ut_id92744
SG2
Prispevkov: 329
Št. objave:#21  OdgovorNapisal/-a Troba » 04 apr 2017, 17:58
Nikjer ne najdem če so kakšni bonbončki zraven,če vzameš v predprodaji?
Tudi VR očala s kontrolerjem ne,al pa spominska kartica,al pa...
Troba
Prispevkov: 163
Št. objave:#22  OdgovorNapisal/-a SG2 » 04 apr 2017, 18:18
pomojem da ni nič... smo v sloveniji ne pa v nemčiji :D
SG2
Prispevkov: 329
Št. objave:#23  OdgovorNapisal/-a mankomander » 04 apr 2017, 20:47
Tako ceno ko ma telekom,se naj jebejo z njim,te pa tak celega plačam,pa ne rabim vezave!G7 je bil ob vezavi za pol cene,saj to je point vezave,drugač pa tak ni nobene logike!
mankomander
Prispevkov: 205
Pridružen: 08 maj 2011, 11:11
Št. objave:#24  OdgovorNapisal/-a KrLo » 04 apr 2017, 22:18
No tudi jaz sem se naveličal iphona, in bo čas, da spet grem na Samsunga 8+, zanima pa me, če ima kdo izkušnje z prednaročili, se dobi ta datum kot obljubljajo, ali se zna grdo zavlečt ?
Pa mi v Slo tudi dobimo zraven AKG slušalke ali spet samo kaki kitajci pa japonci ? :-\
Št. objave:#25  OdgovorNapisal/-a darkside » 04 apr 2017, 23:55
jaz sem s7 prednaročil pri telekomu. dobil točno tisti dan kot je bilo napisano. je bilo pa to prvič da sem kupil v prednaročilu tako da ne vem kako je drugače.
Prispevkov: 12358
